90M TB for Vortech guys????
Old Feb 17, 2006 | 01:04 PM
Blow03SS's Avatar
Default 90M TB for Vortech guys????
Is there a huge benny here? What do you guys think about the 90M along with the LS2 for us non-mag. guys?
Old Feb 17, 2006 | 03:51 PM
FlaBouy's Avatar
I noticed a diff going to the 80MM drive by wire and Pacesetter LT's. I am adding cam/heads next week with a wideband LC-1. With HP tuners I log slightly higher MAF in HZ readings throughout the pull, but I am struggling will fuel Inj duty cycles with the 42# injectors. 60#'s going on next week also. I am planning a 90mm and Fast Intake once I can find a good solution to the drive by wire TB. My Vortech has the 3.12" pulley and I currently pull 12 psi. I would be interested in dyno before/after with a 90mm setup
Old Feb 17, 2006 | 06:36 PM
Keith's Avatar
With the TB on the outlet side of the vortech S/C you will not see as much of a gain by going to a larger TB. The radix guys see a big gain, because the supercharger has less restriction on the inlet side, making for less heat.
It certainly couldn't hurt as you could flow more air into the intake.
Old Feb 17, 2006 | 10:19 PM
krambo's Avatar
I think that as well but it couldn't hurt. I wouldn't expect huge gains.
Anyone else have input?
Old Feb 18, 2006 | 01:22 AM
AintNoHo's Avatar
Measure the boost before the tb and then measure the boost in the intake both on a run to the same rpm. If there's a difference, say 2lbs, then you know the tb is a restriction. I expect the tb will be restrictive and run better with the 90mm.
Old Feb 18, 2006 | 01:54 PM
Blow03SS's Avatar
Not worth the cha-ching then. I will spend the money on the V then!
Old Feb 19, 2006 | 07:52 AM
krambo's Avatar
Nice choice in rides.
Old Feb 19, 2006 | 08:37 AM
greentahoe's Avatar
I had planned on doing the same thing. I even have the LS2 manifold in the garage. Once I made a list of everything that would need to be replaced/ modified, it didnt look to be worth it at all. You would have to relocate accesories, new injectors I believe, fuel rails, and new TB obviously. At that point I just decided to get a turbo.
Old Feb 19, 2006 | 11:13 AM
Blow03SS's Avatar
I think at this point I will just let the truck sit until I can get the meth installed and turn the boost up to 12lbs. Kevin how about it, I should see 510 on the dyno and I have the stock converter......what a joke!
Old Feb 19, 2006 | 09:55 PM
krambo's Avatar
Joke?
I will be damn close to 500RWHP as well and still have a bone stock tranny!
Its all fun. Keep us posted on the V!
