78mm Throttle body and stock intake limits
I have designed them.
Choose wrong materials it will stick.
Wrong bushing (if they used one) will wear out. Spring tension, cam angle,
Blade angle once fully open. Blade angle once closed
As in any part including a convertor it's about how it's put together materials used and the part list used. Not to mention the attention to detail.
Glad the ones you picked up worked. Doesn't mean the part is not worth the money paid by others.
Back in the day throttles were a simple part. Now they are performing lots of unconventional tasks in response to torque requests from different engine software features. Not only that, but in the event you are running speed density on modern vehicles and your MAP sensor dies, the engine can still run because you can estimate manifold pressure based on throttle position and RPM. Manufacturing tolerances and throttle motor response are more important than ever.
Like I said, I bought the cheap chinese knockoff for mock up purposes.
The throttle blade will not close all the way, either due to the machining inside the throat or the shape of the blade.
You can not bolt up the IAC because the hole was machined too small.
You can not bolt up the TPS because the holes are in the wrong location.
Pure garbage.
I could easily see one of these getting stuck wide open and someone not having a good day because of it.
Pure garbage.
Pure garbage.
Pure garbage.
Winner chicken dinner
thats why we all closely inspect our parts before installation i guess.
my first tb i had to drill for the iac to seat properly but worked fine after that.
second one went right in.
i usually will remove tb blade screws and red locktite them and adjust the blade to seat properly.
10 minutes of work for $300.
Even older Professional Products throttle bodies used delerin or plastic bushings on the throttle shaft. They wore away and I could never figure out why the truck wouldn't idle smoothly. This was on a Ford...but still...replaced the throttle body with an Accufab and the problem was magically fixed.
