70 or 76? Or something else?
Old Jul 25, 2012 | 02:04 PM
Ferocity02's Avatar
Default 70 or 76? Or something else?
My original plan of using a MPT70 has fallen through, turns out the used turbo I bought is junk. So this gives me the opportunity to rethink my choice of turbo. I like the idea of a 70mm with a quick spool up. Would a 76mm be noticeably slower? Will a 76mm make the same power with less boost? Here's a little info on my build:
'01 5.3L 2WD
KB T4 front mount, intercooled, 3.5" DP, 50mm WG, 50mm BOV
Stock heads, ARP head studs, LS9 gaskets
212/212 114 cam, Dual valve springs, LS7 lifters, hardened pushrods
Walbro 255 in-tank pump (might be holding me back), Bosch 60# (3bar) injectors
Built T56 6-speed, SPEC 3+ clutch
91 octane only
Looking for 500-600rwhp, daily driven, good gas mileage out of boost
I'm leaning towards 76mm right now. I'm not sure a 70mm would get me to 600rwhp reliably. 72mm maybe? Or any other ideas? Thanks!
Old Jul 25, 2012 | 02:52 PM
Go with a 76mm from on3 performance. With the small turbine it spools just fine and will make the power you are looking for. And they are less than $350 to your door
Old Jul 25, 2012 | 02:55 PM
nonnieselman's Avatar
yea go 76.. that 70 is gonna be pushed hard for that much power..
my buddy has a magnum 76 q trim remote mount on his 5.3 with that same cam, from a roll it hits 10# hard and fast with a 3000 stall and 80E with 3.42s. Stalling it up on the line it does take a second but comes on strong.
9-10# he ran a 12.2 with a 1.8 60'
Old Jul 25, 2012 | 03:19 PM
lglowe's Avatar
I have a different approach to things now. I'm on my 3rd turbo and and I wouldn't have anything less than a 75mm turbine wheel on my truck now. Yea the little on3 76mm is ok but to me I bought a turbo for the power delivery that a good turbo is supposed to do. These little turbine turbos act too much like superchargers TO Me..... I love the way my pt 7675 spools and pulls twice as hard as the little on3 at 5# less boost. I'm even wonting to go to the big Borg warner 87mm now that iv been follwing the backpressure thread.. take it for what its worth.. just my .02c
Old Jul 25, 2012 | 03:29 PM
Ferocity02's Avatar
That's what I'm leaning towards right now. I read through the on3 thread on Tech and overall very good reviews, and the pictures show nice quality. If it breaks just buy another
Old Jul 25, 2012 | 03:51 PM
quicksilverado's Avatar
tc76 Fast spool and will meet your goal easily.
Old Jul 25, 2012 | 04:24 PM
slowec's Avatar
PM me an offer on my used (and working very well) MP76 and I will buy a bigger one.
Old Jul 25, 2012 | 04:30 PM
I agree with you and If I wasnt on a budget when I built my setup then I wouldve gone with a S475 or S480 but I didnt have the money. He said he want 500-600 rwhp and it can easily be done with one of the On3 turbos. I was just giving him a good bang for buck option. On 11psi I ran a 11.59 @115 in my truck and on 14psi I ran a 11.44 @ 121 spinning bad. I know that If I had a bigger exhaust wheel it would run much stronger on 14psi but itll work for now. I will be in the 10s next time out and when I want to go faster Ill save up for a S475
