611rwhp/591rwtq @ 10psi (4500DA)
Old Jun 2, 2011 | 03:01 PM
swift700's Avatar
Wow, very impressive. Although I won't be running such nice heads, I'm hoping for something similar in terms of numbers from my 383. I'll be running the 1900 with a 2.8" and IW pulley setup along with a healthy cam.
Old Jun 2, 2011 | 03:45 PM
CAM-T's Avatar
Those are great numbers to start with. Looks like traction is going to be even more of an issue now.
Old Jun 2, 2011 | 04:24 PM
moregrip's Avatar
what a rush!
Originally Posted by moregrip
Damn brotha! great numbers! congrats! It actually gives me a pretty decent idea of what I'm putting down as I have a 365, WCCH Heads, Healthy Cam running 11lbs of boost (in other words/very similar to your setup)
what are the specs on your cam?
Old Jun 2, 2011 | 04:32 PM
TXBlownTBSS's Avatar
Old Jun 2, 2011 | 04:45 PM
EasyE1986's Avatar
Good numbers man. After the Nelson Tune i wanna get a dyno run to see what my #s are at
Old Jun 2, 2011 | 05:26 PM
TIM Z's Avatar
11 sec. Truck Mod
Those are killer numbers bud!! Cool to see that 1900 pumping out the ponies!
So how do you like the IW pulley?
Ive been contemplating dropping to a 2.7 and an overdriven crank pulley myself, I'd like to see 12 psi on top end.
Old Jun 2, 2011 | 08:22 PM
slowfive0's Avatar
Awesome numbers!!!! Can't wait to see what it does at the track
Do you know what the inlet air temps were?
Originally Posted by TXBlownTBSS
I just had LEP build me a forged 365 with a set of WCCH 243's and a LEP Stage 1 Maggie cam and it put down 611hp/591tq @ 10 psi with 4500 DA in Las Vegas air on a break in tune. It should make 2 more psi back home at sea level and as much as 8-10% more power once broken in. It should put down a nice number at the track once she's dialed in.
BIG Thanks to LEP for building this nice motor and hooking me up with a blower cam, WCCH for their excellent work on the heads and Joe (LeftCoast32) for doing the dyno tune.
Old Jun 2, 2011 | 11:01 PM
moregrip's Avatar
what a rush!
224/230 612/612
yeah, that's the one.....I think Joe was running that one as well or damn close.
mines not quite the same but close 224/238.5
Old Jun 3, 2011 | 12:02 PM
old motorhead's Avatar
I need to figure out what I'm doing wrong. If my fuzzy math is correct, I think you're pushing 4.3% more air than I am with TVS2300 and 3.1" snout pulley. You have a slighly bigger cam and probably better heads (Livernois stage 2 243's on mine). What c/r are you running? LSA on cam? Have you done any updates to the I/C circuit? I'm considering adding a small radiator to the I/C circuit with e fan(s) in my truck bed.
Old Jun 3, 2011 | 02:44 PM
slowfive0's Avatar
Inlet Air Temp????
