6 rib lsa balancer pulley belt question
Old Dec 1, 2016 | 11:48 AM
Lt1z383's Avatar
Default 6 rib lsa balancer pulley belt question
I had a custom top pulley made for my lsa swap I am doing with the lssimple setup and since wasn't going 8 rib figured why not have them do a 6 rib upset to match my factory balancer. Question is guys running the 8 rib upper which end does it ride on? Closest to blower or to radiator? Also those running a 2.50 pulley factory balancer what belt length and is one brand better then another for this setup? Thanks
Old Dec 1, 2016 | 11:58 AM
GM1697's Avatar
I'd be willing to guess that it's closest to the motor, but the only way to know for sure would be to get a laser to line up the pulleys, and see where you are at.
Old Dec 1, 2016 | 12:55 PM
Vortec350ss's Avatar
Greame is correct. When you go 8 rib you add 2 ribs to the outside of a 6 rib set up. The 6 rib belt will sit on the inside 6 ribs.
Old Dec 4, 2016 | 01:57 PM
SUTTERERMAN85's Avatar
No the belt on a 6 rib truck setup runs on the middle 6 ribs on a 8 rib lsa blower pulley.
Old Dec 5, 2016 | 11:33 PM
That's true. I didn't read the question that carefully. The LSA blower pulley alignment is ever so slightly inset from out stock accessories. If you go 8rib in everything else the blower 8 rib pulley would be in 1 rib from everything else.
Old Sep 12, 2017 | 05:02 PM
Ford_Assassin's Avatar
Come Get Some!!
I have the LSA blower on my 6.0, running the stock truck crank balancer. Would the stock (larger diameter) LSA/ZL1 crank balancer work with the correct belt spacing for the rest of the pullies, including the A.C. compressor belt?
