50/50 or distilled water??
Old Jul 30, 2009 | 05:03 PM
cccharged's Avatar
Default 50/50 or distilled water??
Which of these would be best for cooling my Maggie?? I read where distilled should be best bc it can dissipate heat better..? anyone have any info on this? Thanks.
Old Jul 30, 2009 | 07:20 PM
cccharged's Avatar
any difference?
Old Jul 30, 2009 | 10:57 PM
MikeGyver's Avatar
I don't know numbers, but I do remember that pure water is supposed to be much better at transfering heat than antifreeze is. The problem with water and especially distilled, or worse yet deionized water, is that it causes heat transfer inhibiting corrosion in aluminum. Antifreeze has additves just for this reason. 50% is the generally accepted mixture for best freeze protection vs. economy, the freeze point doesn't go enough lower with pure antifreeze to waste the money, and you lose even more heat absorbing ability with less water.
My opinion is that you should use a 5% mixture.
Old Jul 31, 2009 | 12:53 AM
TX Tahoe Z71's Avatar
Subscribed... same question. And I thought the point of using distilled water over regular or tap water is that is wasn't corrosive, is that not correct?
Old Jul 31, 2009 | 02:08 AM
MikeGyver's Avatar
It is because it doesn't leave a coating of minerals is why it is preferred. These minerals interfere with the additives in antifreeze. Either way, I don't think it's critical, I think it is GM that said if it is drinkable, it's OK for a cooling system. I still think some antifreeze is a good thing for corrosion protection, but I'm just some guy on the internet.
Old Jul 31, 2009 | 07:15 PM
boosted_blue's Avatar
Its also known that the corrosion from the minerals in the tap water can cause pits and damage to the water jackets in aluminum heads and parts.
Old Aug 1, 2009 | 11:36 AM
marlboroman71818's Avatar
If you want the best heat transfer use de-ionized water and a product like water wetter or just straight engine-ice. It will cost you but will allow for a lower surface tension on the coolant and allow for more heat transfer.
turbo6c3
Oct 5, 2015 06:11 PM
Tigger Welder
Oct 1, 2015 08:41 AM
Benloe
Sep 22, 2015 10:24 PM
jfuegner
Sep 22, 2015 12:30 PM
Shotguntommy
Sep 15, 2015 05:24 AM
