5-7 psi power with 5.3???
Old Jan 12, 2012 | 07:37 AM
sroka's Avatar
I'm thinking all I would need would be another 100rwhp and 150rwtq to make pulling the trailer more enjoyable.
So anywhere from 330-350rwhp and 450 rwtq. With those small of power levels and pulling a 6000lb trailer really need a better trans? I'm not interested in a 4l80e swap.
Old Jan 12, 2012 | 07:54 AM
nonnieselman's Avatar
You will find out shortly
Id go 80E if your gonna be towing that much alot. Especially if your gonna use all that extra power and TQ.
Old Jan 12, 2012 | 08:18 AM
smokeshow's Avatar
Mod with training wheels
Made 450/440 on a 5.3 with 6psi from a TVS1900... Only other mod was an LS9 cam.
Old Jan 12, 2012 | 09:21 AM
JoeyGC5's Avatar
I made 445hp/431tq on a 5.3 with 234/228 cam and a PT88 with 6lbs of boost. I added a 50hp shot and made 491hp/502tq, and on 16lbs I made 662hp/634tq. So there is plenty of options and potential in 5.3 combos
Old Jan 13, 2012 | 02:58 PM
yurs78's Avatar
Love to see the graph if you have it.
Old Jan 17, 2012 | 07:25 AM
black6spdz's Avatar
It will make pulling a trailer much better for you. I pull my boat that weighs 5k or so every weekend with my turbo 6.0 and it pulls much better than when it was N/A. The biggest thing to watch is intake temps when climbing hills. As for the trans my truck is on a basically stock 4L65e and has made over 500rwhp with just over 8lbs and trapped 112mph in the 1/4. It has been like this for a year so far but I do have an 80e ready to go in this spring.
Old Jan 4, 2013 | 06:09 AM
Choda's Avatar
I made 377 411 wheel w 70mm trick kit at 6 psi. In 2nd gear Bone stock everything else.
I'm up to 8/9psi and hoping for just over 400.
Old Jan 4, 2013 | 08:06 AM
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by WJ MARK
Anywhere between 400-450. I made about 500 with my 5.3 and ls6 cam @ 10 psi. just bumping your timing could gain you 50 hp
Was that with that 62-1? That's the gen 1 kit off my old truck was t it?
We need to get you into a larger set up.
If you gonna be pulling that my h weight. Watch tranny temps, air temps, and don't just stay in boost while going up the hill. Have your tuner set it up for pulling not just max power stuff.
Old Jan 4, 2013 | 08:21 AM
The 18-20 hp is a general rule of thumb. If the turbo is more efficient and piping is more efficient you should see more, also if its not very efficient you will prolly see less. I have no doubt my cam only setup is over 600 rwhp on 12 psi
Old Jan 4, 2013 | 10:31 AM
ZO6Ted's Avatar
Haven't seen you around in a while but I was mia too till a few months ago. How you been? Hope all is well. Man has life changed A LOT for me. OP...sorry, love the thread.
