5-7 psi power with 5.3???
Old Jan 11, 2012 | 02:36 PM
sroka's Avatar
Default 5-7 psi power with 5.3???
What kinda power are people getting with 5-7 psi out of your 5.3? Stock, or modified motor, list your mods also. Single, twin, centrifucal, positive displacement, etc.....
Old Jan 11, 2012 | 02:48 PM
black00chev's Avatar
Slowest turbo build ever!
should be looking around 450 or so at the tires depending on exact setup. On 8-10psi im looking to be in the 450-500 range.
Old Jan 11, 2012 | 03:50 PM
blue0453's Avatar
Mine did 486 at 10. Im at about 13 now and its night and day difference. Its amazing what 3psi will do. Im looking to get to around 15..
Old Jan 11, 2012 | 04:12 PM
quicksilverado's Avatar
You are probably in the sweet spot of the turbo. That more than 3 psi is probably why it feels so much stronger. When I went from 10 to 12 on my old setup it felt the same and I was in the sweet spot.
Old Jan 11, 2012 | 04:28 PM
BlownG8Girl's Avatar
With a Magnuson 5-7PSI would be 100-140rwhp over what you have now
Old Jan 11, 2012 | 04:37 PM
sroka's Avatar
is it safe to say, for every pound of boost you get around 20hp. So 5-7 psi could be 100-150hp over stock? More importantly to me would be the extra torque between 2000-3000 rpms. Hoping 5-7psi would give atleast 150 ft lbs tq more in the 2000-3000 range. Or am i missing something here?
Old Jan 11, 2012 | 04:38 PM
sroka's Avatar
damn you just beat me too this
Old Jan 11, 2012 | 09:15 PM
14psisupra's Avatar
im making 411hp/426tq on 6psi with 5.3l and 212/218 lowlift cam
Old Jan 11, 2012 | 09:27 PM
You are pretty much on the money. I bet it is closer to 18rwhp for each lb of boost. 20 is easier to figure out though.
The torque would be there under 2500 for sure.
I quick like ninja.
Old Jan 11, 2012 | 10:29 PM
WJ MARK's Avatar
Anywhere between 400-450. I made about 500 with my 5.3 and ls6 cam @ 10 psi. just bumping your timing could gain you 50 hp
