5.3 turbo'd guys come in
Old Aug 8, 2014 | 01:10 PM
  #21
George C....'s Avatar
Formerly ScreamingL
look at everyone faster then you and go from what they have for gear
to low of a gear number will put more slip in the converter, the load ppl speak of is the old school way of thinking with a snail. The proven theory of gearing the setup for peak power thru traps will always still play out
gone 160s with 373s and 28" tires
Old Aug 8, 2014 | 02:45 PM
  #22
kbracing96's Avatar
Just FYI, a BW turbo will not even come close to fitting On3 pipes. Whole different turbine housing. They are a mid frame T4 where On3 stuff is all small frame T4 from what I've seen.
Old Aug 8, 2014 | 02:47 PM
  #23
tim wellington's Avatar
Default gears
I think 3.73 and 4.10(my favorite) work great with 4l80e .2.56 first gear ratio. 4l60 has 3.06 and 6l70 has 4.02 first gear ratio .those might not like gears from what I have seen.
Old Aug 8, 2014 | 05:53 PM
  #24
Chevy_King1500's Avatar
cam?
my specs:
2002 5.3
212/218 cam
72mm magnum turbo
stage 2 truck kit
12psi
e85
ran 90mph in the 1/8 shifting at 5500rpm (still working on the tune)
Old Aug 8, 2014 | 07:03 PM
  #25
BlackGMC's Avatar
Resident Retard
I had 4.10s, then switched to 3.42s. I absolutely hated 3.42s. It did not load the turbo better in my opinion. I switched to 3.90s and i like driving my truck again.
Dont fear the gear.
Old Aug 8, 2014 | 07:12 PM
  #26
TrickTurbo's Avatar
Truck Sponsor
Like others said.
The spool to gear load the engine turbos like that.
Is old thinking.
We have had several customers go to
From 342/373 to 4.10.
Run quicker
Rpm faster
But had less boost throu the traps.
Old Aug 8, 2014 | 09:05 PM
  #27
Blackpanther99's Avatar
Yeah im aware of that. I messeged Chad earlier in the day.
Old Aug 8, 2014 | 09:07 PM
  #28
Originally Posted by Chevy_King1500
cam?
my specs:
2002 5.3
212/218 cam
72mm magnum turbo
stage 2 truck kit
12psi
e85
I think ill be going with the Isky 218, but might end up with a custom grind.
Sounds like a beast.
Old Aug 8, 2014 | 09:18 PM
  #29
Choda's Avatar
my stock engine 5.3 has a 70mm has instant boost and actually screams, which I love.
if I had your combo with a cam I would go upper 70s mm.
Old Aug 8, 2014 | 09:23 PM
  #30
Originally Posted by TrickPerformanceProducts
Like others said.
Is old thinking.
Run quicker
Rpm faster
I dont mind that
