5.3 with ls6 cam + radix?
Old Jul 27, 2013 | 11:38 AM
jkroberts's Avatar
Default 5.3 with ls6 cam + radix?
Does anyone have any experience with this combo? I have a 5.3 with the ls6 cam, rods and springs and I would like to add a radix supercharger later on. I know the ls6 cam picks up the top end, how will the supercharger add to the bottom with the cam?
Old Jul 27, 2013 | 11:48 AM
ZO6Ted's Avatar
Great combo and great gas mileage too. Mine was sts and ls6 cam. pulled great to 6400. Look up Trever1t. He had a very similar cam with Radix with a Lingenfelter GT2 I think. Both of us ran 7s in the 1/8 on low boost and pump. May need better springs with boost cause it tries to hold the valves open. Best of luck to you!
Old Jul 27, 2013 | 12:09 PM
Double-L's Avatar
Well I run a 04 SSR on the weekends and a Daily driver for about 4 years, 06-10, A brick at 5200 pounds with me in it, 5.3 a Maggie about 8-10 pounds of boost all stock other than Comp beehive springs and 1.85 rockers, Headers and a converter, Would blow the tires off and on a good day it run 12.78 in the 1/4 and got about 21 mpg on pump gas
Old Jul 27, 2013 | 12:16 PM
jkroberts's Avatar
Thanks Z06ted! My truck won't be built for the track, its more of an offroad/recovery/chase truck. It weighs 6,000 lbs. and i haven't caged it yet. Loaded I think it will be around 7,000 lbs. I just want to nake sure I have enough power to pull a dead truck through the deep stuff then tow it home.
And I only plan on running 5 or 6 pounds of boost, would I still need new springs?
Old Jul 27, 2013 | 12:47 PM
jkroberts's Avatar
Double-L: if I could get my brick to perform like that I would be estatic! Especially the 21 mpg part. I'm averaging 9 mpg mixed with my stock 350. Hoping to get to 14-15 after the swap, and hopefully more with the charger
Old Jul 27, 2013 | 03:12 PM
ZO6Ted's Avatar
May be ok until you decide to turn it up a bit lol.
Old Jul 28, 2013 | 02:41 AM
jkroberts's Avatar
Ill cross that bridg when I get to it
Old Jul 29, 2013 | 08:23 AM
Vortec350ss's Avatar
Mileage will be very dependant on how you drive it. It wont get better mileage than a stock 5.3 does, but it will run very strong.
5.3Okasai
Mar 9, 2022 01:07 PM
Jake99
Aug 8, 2015 07:56 AM
sTNT971
Jul 16, 2015 12:39 PM
Aboss
Jul 9, 2015 10:28 AM
07NBSChevy
20
Jul 8, 2015 07:27 PM
