5.3, 1900, E85. Pump & inj help
Old Mar 2, 2018 | 03:19 PM
94 slow's Avatar
Default 5.3, 1900, E85. Pump & inj help
Hello guys,
I'm running a l33 with an lsa blower and E85. Is anyone else running this setup? Can anyone with experience point me in the right direction for injector and fuel pump help.
Jr
Old Mar 2, 2018 | 03:59 PM
Atomic's Avatar
I have a gauge for that
what do you need help with exactly?
Old Mar 2, 2018 | 04:50 PM
94 slow's Avatar
I need help figuring out which injectors and fuel I should get. I’m hoping to not spend a grand on INjector dynamic injectors.
Old Mar 2, 2018 | 04:57 PM
FFDP's Avatar
I'd suggest at least a 450lph pump if you plan to run E85.
You don't have to only buy Injector Dynamics stuff. FIC makes great injectors too.
650cc (72 lbs/hr at OE 58 PSI fuel pressure) FIC Fuel Injector Clinic Injector Set for 4.8/5.3/6.0 Truck Motors ('99-'06) (High-Z)
These ones right here will support over 500hp on E85 and way higher on pump gas or a mixed blend.
Old Mar 2, 2018 | 09:50 PM
94 slow's Avatar
I was thinking about running the fast 85lb injectors.
Ill look into the walbro 450.
Thank you
Old Mar 2, 2018 | 09:53 PM
FFDP's Avatar
Fast injectors are low quality and have questionable data. There is a reason they cost hundreds less than FIC or Deatchwerks.
Old Mar 4, 2018 | 10:56 PM
B00sted2007's Avatar
Don’t cheap out on injectors, I wouldn’t go with fast injectors... at the least go with some 80lbs ers that Matt Hapel uses on his builds (sloppy mechanics). in my opinion go a little overkill on them, chances are you’re gonna want more power in the long run
urdone
Aug 6, 2012 12:26 AM
black4.8
Nov 16, 2011 11:56 PM
SuperSporttruck
Apr 11, 2008 02:51 PM
Raffman
Aug 19, 2007 07:16 PM
gonzo 6.2
Sep 18, 2006 09:41 PM
