408ci/TVS2300/LSA heads build
Old 08-19-2012, 11:27 PM
  #281
03sierraslt's Avatar
What belt length and blower pulley are you running?
You are running 8rib right?
Old 08-19-2012, 11:48 PM
  #282
Destroyer of Transmissions
1SlowHoe's Avatar
Yes 8 rib. IW 25% crank pulley and a 2.8 on the nose of the blower. (non-jackshaft blower)
I don't remember what the belt length is. I just used whatever length the 6-rib belt was but I don't think I ever compensated for the crank pulley being smaller.
I remember searching and couldn't find a good answer on belt size. I didn't want it to be too tight and cause bearing issues on the alt or PS pump.
I'll look tomorrow and see if I can still read the belt.
Old 08-20-2012, 02:02 AM
  #283
11 Second Hall Moniter
AKlowriderZ71's Avatar
Nice to see you back at it! Start driving that thing!
Old 08-20-2012, 08:07 AM
  #284
You do mean 10% overdriven crank pulley right? And crank pulley is bigger not smaller. If you went with a underdriven crank pulley on a blown setup that would be like throwing rocks at your own house.
Old 08-20-2012, 10:38 AM
  #285
Lucille's Avatar
Might explain why he is getting 8lbs on a 408 with a 2.8 pulley and I'm pushing 10 on a 402 with a 3.4 pulley.
Old 08-20-2012, 11:40 AM
  #286
Ya boost seems REALLY low for a 2.8 blower pulley overdriven.
Old 08-20-2012, 12:19 PM
  #287
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Is yours a jackshaft version?
Old 08-20-2012, 01:02 PM
  #288
1SlowHoe's Avatar
Yes, 10% crank. Sorry, I was working on 2 things as I typed that.
Not jackshaft.
The boost is not really important. The final numbers are. Those LSA P&P heads should flow pretty well so boost won't be so high.
Old 08-20-2012, 01:03 PM
  #289
1SlowHoe's Avatar
what numbers are you making with that set up
Old 08-20-2012, 01:19 PM
  #290
1slow01Z71's Avatar
You said so yourself that your exhaust doesn't flow that well. Everything upstream of the exhaust can flow badass but if its restrictive you're going to have higher boost levels.
Quick Reply: 408ci/TVS2300/LSA heads build
