408 or 370 for F.I.
Old Dec 28, 2008 | 04:47 PM
  #41
Derek @ EDO's Avatar
FormerVendor
Originally Posted by BlownChevy
Why would it take a 370 15 psi to make 600HP? I assume we are talking rwhp here....and I have seen several 5.7L Corvettes make 600 rwhp on less than 12 psi. ****, they can make 550 on 10 psi and the right cam.
If he only wants 6-700 HP keep the CR high to make up for the smaller cubes.
Old Dec 28, 2008 | 04:48 PM
  #42
skyhighsami's Avatar
no title here
I was just using that number as a point of reference not saying you need that much boost, just a number
Old Dec 28, 2008 | 04:52 PM
  #43
Wilde Racing's Avatar
How do I change this text
I think he was just throwing numbers out there.. But you are right skyhighsami, the smaller displacement engine is going to have to work harder to make the same power level of the larger engine.... but is the 408 worth the cost? and some of the down sides? oil consumption is another point I havent seen in this thread. the 408 will burn more oil, but on the other hand you can run the rings tighter on the 408 so maybe that would over come the shorter piston skirts????
Old Dec 28, 2008 | 04:54 PM
  #44
woops, I'm too slow on the reply...
Old Dec 28, 2008 | 05:22 PM
  #45
BlownChevy's Avatar
blownerator
25 Year Member
This is the BIGGEST issue I see with the stroker motors.
Old Dec 28, 2008 | 05:45 PM
  #46
fish5225's Avatar
Mikegyver:
I posted the dyno graph several weeks back, here it is again. We built a completely forged 408, eagle crank, arias pistons, 9.1. TVS 1900 rear inlet with ported LS2 heads, 1.75 roller rockers, etc. With a 2.8 inch pullley we made about 5.5lbs of boost until 6000 rpms when it bumped up over 6lbs. I will try and get the video posted. It can be done.
Old Dec 28, 2008 | 06:00 PM
  #47
FormerVendor
Originally Posted by fish5225
Mikegyver:
Positive displacement blowers and turbos are two completely different animals, lets not get them confused for this particular setup the OP is speaking of.
Old Dec 28, 2008 | 06:08 PM
  #48
MikeGyver's Avatar
Mikegyver:
Wow. Cam specs?
The OP's question was displacement, I think everybody has been comparing 370 to 408, regardless of f.i. method.
Old Dec 28, 2008 | 06:24 PM
  #49
FormerVendor
Originally Posted by MikeGyver
Wow. Cam specs?
True but regardless of CI the Positive displacement blower will achieve a greater amount of TQ down low simply because it produces airflow in a completely different way.
In other words the OP is wanting to go turbo... He will not see a TQ curve like the one posted above from the + displacement blower even if he runs the same boost level with a turbo with that same exact motor. They just make power in completely different manners.
Most guys assume PSI is horsepower instead of actually looking at it as restriction.
Old Dec 28, 2008 | 06:28 PM
  #50
MikeGyver's Avatar
Good post. It should have been #47 instead of #49.
