4" Intake tubing
Old Apr 5, 2012 | 07:46 PM
  #21
AKlowriderZ71's Avatar
11 Second Hall Moniter
Originally Posted by JimS
I don't know what or where I can get a "standard pin kit". Sorry to have to ask you guys to feed me everything with a baby spoon but I'm just not up on this stuff.
Where do I buy it and what do I ask for?
Thanks. Jim
I have a crank pinning kit for sale. You need it!
https://www.performancetrucks.net/fo...ng-kit-497698/
Old Apr 5, 2012 | 07:55 PM
  #22
A Low Dime's Avatar
13 Second Truck Club
Originally Posted by Last Call
Here is a picture of my 4" intake:
Did you notice any decrease in IATs, or faster air intake cool down from wrapping the intake piping? Less heat soak from idling or anything?
Old Apr 6, 2012 | 05:48 AM
  #23
03sierraslt's Avatar
I was wondering the same thing.
Old Apr 6, 2012 | 11:02 AM
  #24
Last Call's Avatar
TOTM: January 2007
I never ran it without the wrap, so I dont know. I am sure it helps some, just not sure how much. The 112 runs hot all the time anyway though!! haha
Old Apr 6, 2012 | 05:09 PM
  #25
xx_ED_xx's Avatar
they do make 102mm TB's i bought a 30 dollar maf adpater off of ebay and welded it to the 4 inch intake pipe. I am SD anyhow but we use it for measuring airflow
Pics
Old Apr 6, 2012 | 06:44 PM
  #26
TIM Z's Avatar
11 sec. Truck Mod
I run a 2 bar tune without the MAF. I picked up .2 in the 1/4 going to the 4" intake and tuning.
Nice!
I need to get my intake fabbed!!
Old Apr 29, 2012 | 05:08 AM
  #27
JimS's Avatar
I'm assuming that.... If I installed the 4" tubing at home I'd have to install the 100mm maf in order to get the truck running and get it to the tuner. Is that correct? Or could the 4" tubing be installed without a maf and then take it to the tuner. I'm assuming the the computer would recognized that the maf was gone and that the engine would not start without the maf.Correct??
Old Apr 29, 2012 | 08:45 AM
  #28
swift700's Avatar
The engine will likely start and run without the MAF. In fact, you'll probably be able to drive it to the tuners, it just won't run great. The computer will refer to the tables in lieu of MAF info.
Old Apr 29, 2012 | 03:29 PM
  #29
JimS's Avatar
Or.. since the tuner is 50 miles away, I could build the new intake setup then reinstall the old one for the drive.
Now just have to build the intake, a new coolant resevoir, maybe a second heat exchanger, get the 2.6" and 10% od pulleys installed and I'm ready for the 2bar olsd tune, then maybe/probably nitrous and new injectors.
Old Apr 29, 2012 | 05:06 PM
  #30
JimS's Avatar
You can use a 10% Overdrive Powerbond pulley ($220):
POWERBOND Supercharger Balancer, 8-Rib, 10% OD, 6.22 OD, 11.75 Pounds (1999-2008 GMC Sierra & Chevrolet Silverado, 2006-2007 Trailblazer SS & 2010 Camaro 6.2L) [PB081190-SC10] - $218.49 : Colorado Speed - 888-592-6661 | GM LSX | FORD MODULAR | CHRYSL
Your intake temps are going to through the roof with a 2.6 pulley and an overdrive pulley. Might want to invest in a larger reservior and heat exchanger.
Where did you locate your battery? I like the heat wrap... it looks hairy.
