4.8L Silverado 2003 what to change for boost
Old Feb 22, 2020 | 08:42 AM
Blake Keller's Avatar
Registered User
Question 4.8L Silverado 2003 what to change for boost
I have 50 mm turbo that puts out 10 lbs boost. My truck had a stock 4.8, only performance tune. what will I need to run my turbo on the truck, want to keep it cheap, if possible
Old Feb 22, 2020 | 08:45 AM
Registered User
I heard maybe LSA fuel pump, lines, Injectors and rails
Old Feb 22, 2020 | 09:03 AM
03sierraslt's Avatar
The turbo isn’t on the truck yet right? 50mm is really small.
tune, injectors, fuel pump
Old Feb 22, 2020 | 09:34 AM
madmann26's Avatar
50mm is like a 4cyl turbo.
Old Feb 22, 2020 | 09:38 AM
my 3.5 has two 50mm turbos (inducer)
Old Feb 22, 2020 | 09:44 AM
madmann26's Avatar
So it’s like a 4.5 cyl turbo. Lol
Old Feb 22, 2020 | 09:52 AM
or does that mean 1 of them is like a 3 cyl turbo? Lol. I actually can’t find good specs on the 3.5 turbos, all I find is that they are Borg K03’s
Old Feb 22, 2020 | 11:12 AM
Registered User
No not on the truck yet and I realize it’s a small turbo but it’s universal, 50 mm front housing and 63 mm rear housing, I don’t want a lot of power just maybe 450 500 if it will even make that much with that turbo
Old Feb 22, 2020 | 11:30 AM
FFDP's Avatar
It likely won't.
Buy a Walbro 450 pump, regulator, 3 bar map sensor, 60-80lb/hr injectors, wideband o2 sensor. You'll need a custom tune done as well.
Then pray the stock 4L60e doesn't explode and same with the factory G80 rear end.
Old Feb 22, 2020 | 11:47 AM
Don’t use that turbo, it’s too small. Universal doesn’t mean it will work on anything. You have to size a turbo for your goals. Just because a turbo will support 400hp on a 4cyl doesn’t mean it will support 350hp on a v8. Exhaust flow is half the equation, it’s not just about the compressor. By the way both the compressor and turbine are way too small.
