4.8L 643hp@12.8psi on Kbracing compound turbo set up
Old Oct 30, 2013 | 01:24 PM
  #41
casper02's Avatar
He got tired of the 4.8 and went with the 5.3 is having issues never got a chance to run on 20psi but did get a E/T:*10.79@127.8*(16*psi) and a best of 131.4 trap speed on 18 psi but was having issues on that run...so you running like home made caltracs?should work good im guessing 373 on the rear ..he was around the same and still running stock tb and intake and heads
Old Oct 30, 2013 | 01:56 PM
  #42
vicalma03's Avatar
Yeah I have a small fabrication shop and build lowering kits, c notchs, traction bars, narrow rear ends and a bunch of other stuff. All my kits are CNC cut and mig welded. They work well. And yes the rear gears are 373. Heres my flip kits and traction bars.
Old Oct 30, 2013 | 02:20 PM
  #43
shifty89's Avatar
Originally Posted by kbracing96
This setup drive's pretty much like a 60mm on a 4.8, but has top end of the big turbo. I don't know why you all think it's gonna have boost response like a roots blower! It's still a turbo setup with a couple of turbine to spin up off idle and it does a pretty good job of it I think. No way you could get this kind of power out of a 60mm turbo alone!
They are BW S480 T6. 96mm/1.32 a/r hot side and Magnum T60 P trim with a T4 .96 a/r hot side.
Very cool man, that's a great sized secondary I'm sure it drives awesome. Two gates I assume? What sizes?
Old Oct 30, 2013 | 02:26 PM
  #44
La Chochita's Avatar
Didnt get to run mine at 20 psi cuz soon as i got off dyno, fuel pressure was dropping, guess the load on dyno wasant that close to being my trucks weight. So lowered it to 18 psi, and ran once with a crappy 1.9 spun all through first gear 10.90@131.4, until next run when my wastegate vaccum line melted with the tranny oil line and made a piston go bye bye...
I also run on flip kit and caltracs, although i kinda like more how urs looks lol..mine are homemade also.
Old Oct 30, 2013 | 04:00 PM
  #45
vicalma03's Avatar
Damn I hate issues!!! So far this time has been the best so far. Best part is I finaly got it tuned right. A 10.9 is still very impressive for a little 4.8. Foose has the time to beat though and im going after it. Haha for now I will try to get my 60ft better. I have a long way to go if I want to get close to foose's time. Think he ran a best of 10.1.
Old Oct 30, 2013 | 04:11 PM
  #46
Yep, i myself also have trouble with hooking, i always debate if i should throw money for some ladder bars or 4 link....either way, best of luck with ur setup. It looks pretty amazing!...i also tried to go close to foose's record but when i saw it was with nitrous on top, i stopped the effort lol...i dont like nitrous :/...
Old Oct 30, 2013 | 04:16 PM
  #47
vicalma03's Avatar
Lol I onna need the nawws!! Ha I Have a Zex wet kit here at my shop just need some time to put it on.
Old Oct 30, 2013 | 04:55 PM
  #48
Git her done and go get those timeslips!!! Haha
Old Oct 30, 2013 | 07:49 PM
  #49
vicalma03's Avatar
I'll have some 1/8 mile times Friday night! Low 7s maybe. hahaha
Old Oct 31, 2013 | 12:42 PM
  #50
Denali08's Avatar
Is this a custom setup or just the regular turbo header modified to feed both turbos?
How does it compare in spool time to the twin turbo kit from TrickPerf?
