4.8 Turbo Build. Need a lil help with cam/turbo.
Old 10-09-2014, 07:01 PM
  #21
gamble686's Avatar
Originally Posted by 03chevytruck
Thinking about tryin to get away with a Walbro 400. Some are running it on a stock returnless....
Gonna be very very tough to make it work. The stock regulator gets pushed thru too easy. The AEM 320 or aero340 should work fine if you aren't planning on e85.
Ok, so I have a noob question... Will a precision 46mm WG and Tial 50mm BOV bolt right onto my On3kit? Would you recommend a different brand WG and BOV? Want to upgrade them so I just need to make sure I don't need to get a particular one.
The flange should be okay, but why do you feel you need something other than the kit peices?
Old 10-09-2014, 07:41 PM
  #22
03chevytruck's Avatar
Because I know someone that was tuning an on3 kit and it built up to 13 pounds with like the 6 psi spring. Even removed spring.... Very reputable shop so I'm going to just upgrade. Going to upgrade turbo also but that's a little further down the road.
Old 10-10-2014, 10:47 AM
  #23
Just got off the phone with Geoff at EPS. Working out the fuel system and tuning items that will be needed to dial it in on tune day. Should have everything ordered this month and will just be waiting on the custom cam to come in!! Going faster than I had expected. Told myself to just order turbo kit and then I could slowly get everything else..... Well that didn't happen! Lol
Old 10-10-2014, 10:59 AM
  #24
oakley6575's Avatar
It took 2 months for me to get my EPS ground cam. So hopefully he doesn't keep you waiting like me. I've heard stories of people ordering custom cams from comp directly and having it before the weekend.
Old 10-10-2014, 03:48 PM
  #25
Had my last one from him in 3 weeks and that's what he quoted for this one. I am gone 2 weeks at a time for work so it will be a couple months before everything is installed anyways. Hopefully it won't be a couple of months on the cam though! Want to put it in ASAP before the turbo is installed.
Old 10-11-2014, 11:37 PM
  #26
Will this get me to 600hp on the rollers? What can I expect on 15 psi?
Attached Thumbnails 4.8 Turbo Build. Need a lil help with cam/turbo.-image.jpg
Old 10-11-2014, 11:41 PM
  #27
caliSSclone's Avatar
Subscribed I'm on the same boat .
Old 10-12-2014, 08:38 AM
  #28
I think it will be close on the 4.8 at 15psi. That will probably max that compressor out.
Old 10-13-2014, 05:59 AM
  #29
boostedsl2's Avatar
70 mm should be good for 700 at least. If I had to do it over I'd buy a pt7075 which is close to what you have (I have a s480).
Cam wise there are a bunch of off the shelf cams that are fine. Texas speed has a couple. Most seem like they are running some type of 210-220 @ .50, .580-.600 lift, 113-115. This should get you no overlap which will be good for your kit but open things up a bit.
I'm not a big fan of custom cams, but to each and his own.
For your fuel setup. I went with an external fpr on the stock rails. I have a single 340l, but I would put 2 255s or a single 400 on without worry. I have a thread in my sig if you're curious on how to do it.
Old 10-13-2014, 09:19 AM
  #30
I don't see a sig for you boosted... I guess it's because I'm on my cell phone? I'll see if I can find it. Fuel system is the main thing I haven't got worked out yet.
Quick Reply: 4.8 Turbo Build. Need a lil help with cam/turbo.
