4.8 turbo
Old Mar 20, 2007 | 02:22 PM
kbracing96's Avatar
Originally Posted by gordz32
don't you need at least a 4.00" bore for the 317 heads?
No, several guys on here have put 317 heads on 5.3 boosted motors to drop the compression.
Old Mar 20, 2007 | 02:32 PM
gordz32's Avatar
sweet!
Old Mar 20, 2007 | 02:48 PM
TurboGibbs's Avatar
Can you safely run 10psi+ boost levels with just fuel, hardware, and a tune+
Also, whats size turbo should I be looking for?
I've seen as high as 14psi run on a bone stock 5.3 with 180k miles on it with no issues. The proper tune, fueling, and intercooler and it can be done. Especially if you drop the compression with 317 heads. With stock compression meth injection would probably be required for much over 12psi.
Old Mar 20, 2007 | 02:59 PM
8ALTNG's Avatar
I would run a 60 to 67mm turbo. depends on cam and CR
Old Mar 20, 2007 | 03:26 PM
vanillagorilla's Avatar
Make sure you get a 0.81 A/R or smaller exhaust housing too.
Old Mar 24, 2007 | 09:30 PM
cpelton's Avatar
.68a/r is the way to go for the 4.8, and exhaust wrap from headers back
BoostedBowTie
Jan 3, 2020 06:46 PM
Rafe19
Oct 18, 2016 12:27 AM
03regcab sierra
20
Aug 3, 2015 12:11 AM
Cowboy17
Jul 9, 2015 08:22 PM
