370 tvs2300 run maf or no maf???
Old Mar 13, 2011 | 03:44 PM
ltr450ryder's Avatar
Would if they had a book to use it cuz be nice to tune the 5.3 for.now and make it run better etc. Any one got any help for me on the hpt?
Old Mar 13, 2011 | 04:15 PM
blackcash's Avatar
I have two of Grag Banish's books. Designing and tuning EFI systems, and, Engine Management - Advanced tuning. Lots of info and only like 35 bucks. Buy them.
Old Mar 13, 2011 | 04:20 PM
sweet thanks guys what i need cuz i wanna see how fast the 5.3 goes with what i have done to it and im putting the lvl7 flt and a sc2800 t/c in this week. cuz the opening week of the strip here is the 2nd weekend in april
Old Mar 13, 2011 | 05:41 PM
just ordered the books off amzon 27 bucks shipped thanks guys ill let u know howit goes thans for everything
Old Mar 13, 2011 | 09:11 PM
loloone's Avatar
LS1Tech Editor
A bit of a newb question, but how do the SD tunes act with daily drivers and ever-changing weather conditions? Do you have to tweak it until you can get it right? Weather isn't too extreme here in Ca and a buddy of mine had a H/C F-Body on SD and LOVED it. But it wasn't his DD.
I know eventually I need to bite the bullet and learn how to tune my own truck, it'll probably help a lot in the long run.
Opening up the intake side of my Radix 5.3 and trying to decide between a 100MM MAF and going SD myself.
Old Mar 13, 2011 | 10:03 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I DD mine with a SD tune. Pretty sure my weather swings are alot more severe than anything you will ever see.
I have no troubles at all.
Myth BUSTED! lol
Old Mar 14, 2011 | 09:55 AM
xsports33's Avatar
I run 2bar CLSD and have no issues with weather or altitude.
Old Mar 14, 2011 | 10:44 AM
BigKID's Avatar
The problem with your 01 is not going to be a MAF limitation but the inability of the stock PCM to process information above 512 lb/min. I maxed out my MAF table on 9#. I have been running the HPT 2bar SD OS for a few years now and have had no issues with it. If you are planning much over 15#, you may consider the 3bar OS.
Old Mar 14, 2011 | 10:48 AM
Ya I wanna run 14-16# and ill Prolly do the 2bar olsd cuz I don't wanna spend a few hundred on a 100mm maf either
Old Mar 14, 2011 | 11:22 AM
krambo's Avatar
There are ways to not "max out" the MAF and still run a stock 1bar OS for this set-up. Tuners have been dialing in big boost set-ups simply by equally scaling roughly 25 tables in the tune file. Sure the table resolution is slightly compressed however it is a viable alternative to the 2bar SD standard answer.
BTW, I did just this as my old set-up maxed the MAF by 4500rpm IIRC. She ran high 11's and pushed over 530 to the wheels @ 5500lbs.
