30 lbs?
Old Sep 3, 2013 | 07:52 PM
03sierraslt's Avatar
A 78mm will feed allot more then a 4cyl. There is also allot more to a turbos size then just that.
Old Sep 3, 2013 | 08:22 PM
TXsilverado's Avatar
Just because he is showing 30 psi doesnt mean his top end is ingesting as much air as a LS engine.
Old Sep 4, 2013 | 08:51 AM
Vortec350ss's Avatar
Thats basically what I was driving at. I'd take a well thought out LS engine making 15# of boost over that 351 in almost all cases. I would expect almost 700 ponies from a 6L running 15+, but I never hear of a small block ford making that kind of power. The 6.0 on the other hand... not uncommon.
Old Sep 4, 2013 | 01:45 PM
custm2500's Avatar
Ph.D. in HUBRIS
Originally Posted by Random User
Have you ever said anything good about anyone's car or truck?
I said I liked the look of the car. I honestly don't event stop to look at mustangs usually but this one looked pretty good. So I nicely talked to him for a short while and asked what it ran since I saw it was still ford powered. He actually told me he was strongly considering an LS swap.
But from my limited knowledge he was lying about the boost. I didn't call him out on it because I didn't know. I was going from an educated guess that so many guys run 78mm and much larger but still only run 20-25 psi at max. That is why I came here and tried to learn something or validate my incorrect thought.
Old Sep 5, 2013 | 06:38 PM
Choda's Avatar
id like to see a truck on here peg a 30 psi boost gauge
Old Sep 5, 2013 | 09:21 PM
Random User's Avatar
My F250 would do 75 on a bad day....does that count?
Old Sep 5, 2013 | 11:17 PM
Atomic's Avatar
I have a gauge for that
Find a guy with a big engine and small turbo, he can make 40psi pretty easy but wont make **** for power. Turbo compressor are work consuming devices, they take power to drive (same thing as your shop air compressor plugged into the wall). Backpressure at 40psi of boost would probably be 60-100psi, which would rob the engine of most of the power it made over say 25psi.
You actually want to run the highest boost you can because you get the greatest volumetric efficiency in the cylinder that way. What makes power is the mass of air being moved, which is not the same thing as the pressure it is moving it at.
Short version: the more your heads flow, the bigger turbo you want and the less boost you need.
Old Sep 11, 2013 | 03:03 PM
custm2500's Avatar
Ph.D. in HUBRIS
The larger turbo won't create as much back preasure on the hot side is a big reason for geting a larger turbo and staying at 20ish psi of boost?
Old Sep 11, 2013 | 03:44 PM
Atomic's Avatar
Yep, exactly.
Old Sep 11, 2013 | 04:00 PM
I think that's part of what he is saying. Every turbo has a certain efficiency range as far as how much air it can move and what boost levels it is happiest at. He is saying that on a larger engine the turbo can actually restrict airflow on the exhaust side, causing more pressure to be made on both the intake and exhaust side without actually flowing any more air. Without the turbo causing that problem, its more a function of how much air the engine itself (heads etc) can flow.
