Which 3 bar map sensor
Old May 8, 2017 | 09:24 AM
m6c5's Avatar
Default Which 3 bar map sensor
So I've been doing some research on which map sensor to purchase but I've having trouble determining which part number will fit my intake and if I will need a new plug for it as well. I have an 03 2500 with the 6.0.
Old May 8, 2017 | 10:22 PM
Gadgetized's Avatar
I can make one for you that will plug right in. How much boost do you plan on running? A 3 bar will go to 29+ PSI of boost. PM me if you would like.
Old May 9, 2017 | 07:25 PM
m6c5's Avatar
I only plan on running 15 psi for the time being but I want room to expand if I want.
Old May 9, 2017 | 10:46 PM
LPCWS6's Avatar
not a 3 bar but this is what I got. 2.5 bar map . It's ugly as hell but it's what my tuner recommended.
Old May 10, 2017 | 04:59 AM
m6c5's Avatar
What makes it so ugly?
Old May 10, 2017 | 10:22 AM
jtphelps289's Avatar
You can order a oem zr1 map sensor for less than $50 from Amazon
Old May 10, 2017 | 10:30 AM
m6c5's Avatar
Does that fit the truck intake?
Old May 10, 2017 | 08:13 PM
That's what I was concerned about, but I got confirmation from three6gmc that it does fit the truck intake if your stock truck map is a single bolt map sensor as well. I just got mine in the mail today hopefully it'll be put on along with the rest of my turbo kit starting before next week if work will ever allow me the time to start on it
https://www.amazon.com/gp/aw/d/B008Y8V1QM/ref=ya_st_dp_summary
Old May 11, 2017 | 10:01 PM
LPCWS6's Avatar
It is a stock map from gm cut open and modified. After it's modified it's filled in with epoxy and looks like crap.
