3.5" or 4" downpipe
Mine is actually closer to 2.5-.2.75 because at the time Kyles jig was off and my downpipe mounted to close to the frame. It's self clearance to this point now.
The closer to the motor, the higher EGT, the MORE volume of exhaust gas you have. (hot gas is less dense, cooler gas is more dense) The further away from the motor you get, it cools and the LESS volume you have, there for the less exhaust size you need.
I would like you to do a dyno test comparing down pipe size. Only change the pipe and make tuning corrections too see if it helps enough to worry about at your power level. Would be interesting. Even though the outlet on the turbo is only 3" there are like 4 45* bends on the first couple feet that has to be restricting some.
Actually, you have that backward
The amount or volume of gas is the same from the point it leaves the headers/turbo to the point it leaves the tail pipes, it doesn't go anywhere but thru the pipes.
The only difference is temperature, as it cool off it becomes more dense and hints, flows better in larger piping.
I've read dyno results from a turbo builder (forcedperformance.com) where they swapped a 2.5" 02 housing to a 3" 02 housing on 600HP build and the dyno results supported no gains. This is about a 10" pipe coming directly off the turbo. The reason stated was due to the high EGT thus resulting in less density at that point in the system, there was no advantage to larger piping.
They sell both products and the 3" cost an extra $150 bucks, but they provide the data there is no reason for it unless you need to be able to say, "yeah it's 3" off the turbo".
Agree to disagree?
Long story short, just go with a downpipe and exhaust that is large enough so you know you won't be maxing it out. Hence my original question. Sounds like a 3.5" DP will suffice for my desirements.
GXPJAY
Feb 13, 2022 08:15 AM
GXPJAY
Jan 27, 2016 11:45 AM
BlackGMC
Aug 18, 2015 01:11 PM
