3.3 bar map from a duramax
Old Aug 29, 2006 | 10:02 PM
TURBO8's Avatar
Default 3.3 bar map from a duramax
Will this work on the gas trucks? It has a 5 volt input. Will hp tuners work with this map?
Old Aug 29, 2006 | 11:07 PM
kbracing96's Avatar
You cab probable scale the sensor so it reads correctly, but the tables will only go to 3 bar I would assume.
Old Aug 29, 2006 | 11:22 PM
vanillagorilla's Avatar
Are you planning on pushing that 5.3 past 29psi?!?
Old Aug 30, 2006 | 06:15 PM
TURBO8's Avatar
No, I dont think old betsy can take too much more. I just wanted to use the duramax one because it looks like the same type map as our trucks use. I think I will just use the old school style 3 bar, just keep it simple. Thanks for replying.
Old Aug 30, 2006 | 06:35 PM
Stoichiometric's Avatar
Is there any resolution lost when switching from a 2 bar to a 3 bar? When I build my 408 I wanted to boost ~12-15psi, should I go for the 3 bar right off the bat? Sorry to steal the thread but I thought this could fit here.
Old Aug 30, 2006 | 06:50 PM
Blown02Sierra's Avatar
How is a 5.3 holding up to 20 psi!?!?!?
Old Aug 30, 2006 | 08:04 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Low CR and a prayer
Old Aug 30, 2006 | 09:22 PM
TURBO8's Avatar
Low CR and a prayer
You aint lieing! LOL. So far so good, I think it's all in the tune. One little mess up and boooom!
Old Aug 30, 2006 | 11:03 PM
I got my 3bar on ebay from tunertoys. It came with the connector too which you'll need.
Old Aug 31, 2006 | 12:49 PM
TURBO8's Avatar
Yeah, I was looking there. Ebay has the best prices I've seen so far. Thanks for the heads up.
