2bar Map not reading right
Old Jul 25, 2010 | 06:45 PM
DrX's Avatar
DrX
Originally Posted by joeyc125
That helps, in HPT, i have a scalar that is recommended to be 200, and an offset recommended to be 10.33. That is what I started with, so you are saying I should adjust the scalar from 200?
Yes. Log the reading off a vehicle equipped with a 1 bar sensor, log your 2-bar at the same location and time, and adjust from 200 as necessary so that it it reads the same. See where that gets you.
Old Jul 25, 2010 | 07:26 PM
joeyc125's Avatar
11 Second Truck Club
Will do, thanks.
Old Jul 26, 2010 | 03:37 AM
Blown06's Avatar
8 Second Truck Club
I think you have to delete the MAF pid in the scanner table as well. I could be wrong though, its been a while since I've looked at the SD set up how to in the Help section.
Old Jul 26, 2010 | 02:51 PM
TURBHOE's Avatar
In the scanner there is a two bar lid and then there is a gm two bar pid. The gm two bar is scaled for just that, a gm two bar sensor. I'll have a look at mine in a few and post numbers up.
Old Jul 26, 2010 | 03:19 PM
joeyc125's Avatar
I am not seeing the GM 2bar, just the manifold air pressure 2bar
Old Jul 27, 2010 | 07:25 PM
joeyc125's Avatar
You ever look at those numbers?
calsdad
Jun 14, 2023 11:07 PM
JordanH
Oct 3, 2015 03:59 PM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
Lthompson
Oct 2, 2015 12:45 AM
WICK3DxGATA
Sep 24, 2015 06:56 PM
