2300 TVS supercharger
Old Sep 12, 2009 | 11:10 PM
mtmm's Avatar
Default 2300 TVS supercharger
Hey all (new to site),
I have a 2009 excab Silverado 2500 HD (4WD).need some opinions?
Current setup :Engine 418 ci, 6.2 LS3
6.2 Mahle 10.5:1,Con Rods- Lunati HD 6.125in
Camshaft, custom, 600 HP Comp
(lift intake .572 ex.593 Duration @ .050 in 230 ex 242)
Cyl Heads L92,Cylinder Head Porting Option,ls7 42 LB injector .
stock transmition 6 speed.longtube headers.
I was thinking of using Magna Charger 2300 TVS supercharger(The price if possible)
Can I installed on the engine without changed something in engine
If need what changes to give more Horse Power
& any idea whats the max psi we could get out of 2300TVS.
need your help
By the way, I'm not car mechanic
Old Sep 12, 2009 | 11:17 PM
SincalT/A's Avatar
Imo your engines to big for that blower.Personally a nice forged Ls1 with 10 to 1 would better suit your needs.
To get a reasonal amout of boost in to that engine your going to have to spin it pretty hard therefore heating the charge to much and losing flow.What's your goals?
Btw:You don't have to yell lol.
Old Sep 12, 2009 | 11:27 PM
scooter k's Avatar
need your help
Probably won't be able to make high boost numbers. Ask Joe at Leftcoast32, he can hook you up with supercharger and answer all your questions. Very knowledgable on these and always there to answer questions. He is a sponser here.
Old Sep 12, 2009 | 11:46 PM
leftcoast32's Avatar
FormerVendor
With the compression at 10.5 to 1 and the displacement 418 cubic inch. I would expect to get around 12-13 psi out of the Front Inlet/Front Drive TVS2300 with the right cam and 8 rib drive system. The compression will help with the boost and give great power when not in boost.
If you want to push it harder then the Front Inlet/Rear Drive (Jack Shaft Style) will make plenty of boost with the right cam and the 8 rib drive system.
mtmm's Avatar
the Engine gives a high-performance in my trucks but I think to add more power with tvs2300
Old Sep 12, 2009 | 11:57 PM
SincalT/A's Avatar
Well if your looking for jus more power than where you currently setup then yeah it will work.Is it optimal for a 2300 no.
Old Sep 13, 2009 | 02:11 AM
Spoolin's Avatar
GFYS and STFU
Where are you from?
Old Sep 13, 2009 | 09:13 AM
SuperchargedSS's Avatar
Originally Posted by Spoolin
Where are you from?
yeah, A/S/L?
Old Sep 13, 2009 | 09:52 AM
MoeDenali's Avatar
I think Dubai
Old Sep 13, 2009 | 11:10 AM
mtmm's Avatar
Where are you from?
from UAE dubai
