2015 5.3 Silverado Build (blower/cam) pics/video
Old 07-22-2016, 01:45 PM
KB Silverado's Avatar
Originally Posted by Choda
Awesome build man.
Can you list the part numbers for cam, injectors and brake kit?
LT4 Cam 12642245
CAMSHAFT | Genuine GM | 12642245
This part #is discountinued, but CMB has some in stock on sale of $250 for the set.
LT1 injectors # 12668651
GM 6.2L DIRECT INJECTION STYLE FUEL INJECTOR SET
Here is the replacement part #, they are more like $480 a set.
Replacement LT1 injectors 12668652
INJECTOR for 2015 Chevrolet Corvette|12668652
Wilwood BBK
Front
https://www.summitracing.com/parts/wil-140-8992-d
Rear
https://www.summitracing.com/parts/wil-140-9407-d
the stainless lines that wilwood recommends for the fronts fit fine, actually a little longer than i would like but the shorter version is to short. for the rears the lines wilwood said would work, were to short and i had to get a new set that were longer. i'll measure the length over the weekend and let you know the correct length.
Old 07-23-2016, 11:19 PM
RedLS's Avatar
Do you have any other pics or info on that fuel line. I couldn't see what was different on it.
Old 07-23-2016, 11:24 PM
RedLS's Avatar
Nice build btw..
Old 07-24-2016, 01:11 AM
here are more pics. the check valve with the 4 pin holes was in the fuel line,which really slowed down the delivery. that valve has been eliminated and now flows straight through.
Old 07-24-2016, 07:53 PM
rjw
rjw's Avatar
Location: Tinker till it blows, then back it off a notch, maybe!!
very nice...!!
a couple of questions:
what did the fuel line cost?
who did the tune? what tuning software? hpt? efi live?
what kind of dyno for those numbers
thx
Old 07-24-2016, 08:14 PM
Originally Posted by rjw
very nice...!!
thx
Thanks!
Fuel line was $100 from custom built motors "CBM"
Tom VanVugt at izzy performance and it was done on HPT.
Mustang dyno.
Old 07-24-2016, 08:39 PM
07Softail's Avatar
So all you installed was the LT-1 Injectors and the fuel line and the fuel starvation was fixed? What abut the LT-1 HPFP?
RT
Old 07-24-2016, 08:56 PM
RT
i also installed the LT4 cam which has a larger fuel lobe. at 9psi and fueling has been fixed.
Old 07-24-2016, 09:15 PM
07Softail's Avatar
Oh ok...I didn't know the tri-lobe was larger. Thanks
RT
Old 07-24-2016, 10:32 PM
RT
i just noticed you are running 305/45/22's. your wheel is a 22x9 stocker, correct? how do you like the ride? any negative side effects to running that wide a tire on a 9inch wide wheel?
Quick Reply: 2015 5.3 Silverado Build (blower/cam) pics/video
