2 bar vs 3 bar MAP sensor and HPTuners
Old Apr 29, 2014 | 11:20 PM
  #21
timmay208's Avatar
thats funny i just closed the tab with that bottom link, i was wondering if those were any good
Im all for 3 bar if the resolution isnt going to be a big deal, if its going to come to better drive ablility with the 2 bar id stick with it but if not then may as well go 3 bar now and be done. Now i just gotta keep myself from turning the boost up haha
Old Apr 29, 2014 | 11:25 PM
  #22
boostedsl2's Avatar
My truck runs like stock. No resolution issues at all. I was pleasantly surprised at how easy it was to setup up the base tune and how it fired right up. I know enough to be dangerous, but I am not a tuner by any means.
I will say that you need to make sure to get your injector setup correct other wise it will run like ****. Also make sure you don't have vats turned on or at least you have it set to the right value. it'll start for a second and then die, you'll waste an hour trying to check everything else, you'll set it right and it'll just fire right up lol.
When you get closer if you need any help, I might be able to point you in the right direction.
Old Apr 29, 2014 | 11:30 PM
  #23
timmay208's Avatar
my vats shows
serial
PWN
None
Not sure what each means. Yea ill be running 2013 gt500 injectors which im trying to find out all the correct info
on the hpt forums someone posted the stock gt500 map but i guess i have to convert everything so im still trying to figure all of that out. The GM tuning stuff is new to me. Im used to AEM, hondata, chrome, ecuflash from doing imports but my LSX knowledge is pretty much 0
Old Apr 29, 2014 | 11:42 PM
  #24
boostedsl2's Avatar
my vats shows
serial
PWN
None
lol, so was I when I started my truck. Import fo life yo.... or not, especially when you want to make some power without spending 20k.
For the Vats setting.... basically if it doesn't start toggle between them and one should fire it up.
I'm running deka 60's, so I my settings wouldn't be that helpful. Don't gt500's use deka 80's?
Old Apr 30, 2014 | 12:05 AM
  #25
timmay208's Avatar
specs i can find show 55lbs@39.1 psi, all of the maps were posted up over there from a stock car, and i guess there is a conversion chart to convert it all to HPT. Hopefully i can figure all of that out
http://www.hptuners.com/forum/showth...T500-injectors
Old Apr 30, 2014 | 12:55 AM
  #26
boostedsl2's Avatar
GT500 injectors
Duuurrrrr I'm thinking of a cobra. My bad
Old Apr 30, 2014 | 05:06 AM
  #27
cpolaris502's Avatar
So HPTuners can make a custom OS from my stock computer and that will keep everything working like column shift and A/C? IF that's true, I might as well go 3 bar now, I didn't build a forged motor to baby it.
But if I'll lose some of that stuff, since I wont be boosting like crazy right away, 2 bar can do for now.
natejk
Nov 15, 2016 08:05 AM
Porscharu914
14
Jan 20, 2016 10:45 AM
Tydriver
45
Oct 23, 2015 09:19 PM
chvy=power
Oct 20, 2015 09:08 AM
chopperloco
Sep 28, 2015 08:40 AM
