15 Silverado 6.2L TVS2300 Belt Drive Help
I have a stroked & cammed 6.2L 2015 Silverado with the Magnacharger Radix TVS2300 with the 72MM Pulley. Unfortunately just around 5200 RPM's I am experiencing belt slippage on the dyno and I loose 3-4 Ibs of boost. I am also running the 8 rib Innovators West OD crank pulley. Has anyone seen any options for alternative belt drive system or additional tensioner's.
Are you running still running a 6 rib belt and stock tensioner? I see you have the overdriven 8 rib balancer.....
As mentioned, can you post a pic of the blower pulley showing how much belt wrap you have?
Yes I am still running the 6 rib belt set up and to my knowledge no one offers the 8 rib conversion for the Silverado to date and here is the current belt routing before the smaller pulley.
I imagine that you could work with Innovators West and Joe @ Leftcoast32 and yall could get an 8 rib conversion knocked out. May take some trial and error........but if you can get it figured out first......you'd be the man.
