112...will it work?
Old May 5, 2008 | 03:25 PM
  #21
hyeride00's Avatar
good idea......save $$ for the upgrade later
Old May 5, 2008 | 03:36 PM
  #22
hyeride00's Avatar
hopefully everything will go smooth with the swap. i have the trans removal down to under an hour....i am guessing the engine wont be as easy....i havent removed one from my truck b4.
--should i take the s/c off before i pull the engine?
--also when i reinstall, should i put s/c on b4 or after the engine is in?? i remember one of the bolts in the back of the s/c near the firewall was extremely hard to get to when it went in the first time.....
Old May 5, 2008 | 03:39 PM
  #23
supersub's Avatar
I would pull the blower first, use a lift plate designed for the ls motors that makes everything a little easier.
Old May 5, 2008 | 03:43 PM
  #24
hyeride00's Avatar
where is a good place go get one of those?
is there a fancy do-hickey of a tool that magnuson has for tightening the rear hard-to-reach bolts for doing the installs? or any other tools that can make it easier?
Old May 5, 2008 | 06:23 PM
  #25
old motorhead's Avatar
Originally Posted by Last Call
I wouldnt say you are limited to 450rwhp. I made 448 with about 5psi on my lq4. Meth and a 2.9 pulley got me to 475. 90mm and tuning got me to 505rwhp. More tuning and I made 513rwhp on the 22's. I have seen 545rwhp on the dynapack dyno which reads power output right from the axles hub.
Allen Nelson flogged my setup pretty good. He's tuned more than a few of these. I, as well as many others, trust his tuning acumen. His dyno is pretty stingy though. Not saying that you didn't make these #'s. Just saying the 112 is limited on the larger cubed engines.
Bottom line is that the truck will haul some serious *** regardless of what a dyno says. It just won't build much more than 8psi and won't make the #'s that a larger blower/turbo will. 8psi on a "built" motor is kind of a waste in my book. 10+psi is very livable on a stock 6.0L if the tune is on the money. Forge the pistons, upgrade the rods, and the 6.0 is left breathless with the 112.
shawn96gmc
May 17, 2016 04:15 PM
Stainless Works
Apr 10, 2016 04:34 PM
Stainless Works
Aug 4, 2015 12:56 PM
atxlt
Jul 20, 2015 11:06 PM
Nimoryan
Jul 5, 2015 03:50 PM
