104oct?? What are yalls opinions?
We are goin to the track This sunday. I was thinking about mixing some 93oct and 104oct just to get it a little higher.
Im at 6psi Intercooled, would this help or hurt any?
Goin to try to dial my tune in.... got to get that WB installed ASAP!!
But would the 104 be a waste of money?? It sure does smell good...
i usually run 93 and 110 at a 50/50 mix when i know i'm going to the track and running high boost... otherwise, when i'm running low boost and low boost tune I stick with 93.
BTW- I love the way 110 smells... and in the morning when my truck is running pig rich and with no cats... mmm mmmm good. Walk behind it and it'll make your clothes smell like race fuel for the day too LOL
You may have a problem
Originally Posted by quicksilverado
Don't waste your money at 6 psi.
GFYS and STFU
This should be your order of buisness.
Change boost first, you can go up to 10 psi safely.
Change up your timing to accomodate added boost.
Then if you still want more add race fuel.
You can achieve the same powerlevels you might attain with race gas by simply upping the boost a bit.
Boost>timing as I was taught
