10.5 :1 plus 9-10psi to much?
Old Jan 15, 2010 | 09:32 AM
SimpleManLance's Avatar
Default 10.5 :1 plus 9-10psi to much?
would 10.5:1 compression be to much for a 03 6.0l running 9psi on a 122hh?
Old Jan 15, 2010 | 09:48 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
I dont think so. In my opinion 10:1 is a good CR for modified roots blowers. The Ls2 seems to work well with them too. Might want some meth to keep it safe
Old Jan 15, 2010 | 10:57 AM
Bromaguire's Avatar
I am running 9.5psi right now on my Denali. I have a whipple blower and no meth. My engine is fine with that much boost. I've ran up to 12psi before I had an intercooler and other than high IAT's and a bad tune from one of the vendors here the engine has held up fine.
Superado's Avatar
11 Second Truck Club
agreed...shouldn't be an issue...
Old Jan 15, 2010 | 11:06 AM
LsxCody's Avatar
just keep some meth handy lol
Old Jan 15, 2010 | 12:10 PM
Bromaguire's Avatar
What kind of IAT are your maggie guys seeing around 10psi? Is the aftercooler not able to keep the temps down once you start to raise the boost? My A/A FMIC keeps my temps down perfectly. I wouldn't use meth unless it was absolutely nessecary. To me it seems like a band aid for an everyday car. I've got a 100% meth Aquamist kit on my Turbo M3 but I don't drive that everyday and it would be a pain to have to fill up gas and meth if I was on a road trip somewhere. I use my kit strictly for performance not to help my IAT's.
Old Jan 15, 2010 | 12:55 PM
trever1t's Avatar
Meth only comes on when into boost, are you in boost all the time, no. I have mine set to come on ~5lbs. I am pretty quick at 5lbs., fast enough A washer tank of meth lasts me more than a month of everyday driving. 5 gallons a year. Meth has other properties. Keeps everything nice and clean
Old Jan 15, 2010 | 01:00 PM
Superado's Avatar
you beat me to saying the exact same thing
Old Jan 15, 2010 | 01:20 PM
Bromaguire's Avatar
I understand that it can be setup to only come on under boost, but I am in boost a lot. I didn't put a blower on my truck to drive around at idle or close to idle.
What % of meth are you running? How many miles are you driving in a month, all that comes into play when figuring out how long a tank will last. I don't think meth is bad but its just a bandaid for high IAT not really a solution in my eyes. I would rather add meth to make more power not to coverup an underlying problem.
What does your setup make with out the meth and n20?
Old Jan 15, 2010 | 01:23 PM
trever1t's Avatar
Meth does little to nothing for IAT's.
It's not a bandaide, it is a method of increasing octane, allowing more timing.
I can stay out of boost and roast my tires
I drive ~25 miles a day, sometimes a little more with taking the wife to work and most of it in city driving. If I was in boost like you say I'd be in jail today
Without nitrous I dyno'd soething like 575hp...i dont remember, see the graphs on page 2 if you click my sig.
