10.05@137 on 14lbs Video inside!
Trying to bust into the 9's with as little boost as possible. Im running 14lbs launching at 6lbs. Came close! I think ill get it the next outing!!
Tried launching with 8lbs but spun. Im going to try 8lbs again on another track that does a little more prep work.
Turbo Silverado on 14lbs - YouTube
Forged 370 9:1 CR
Stock crank
Wiseco Pistons
Callie's Rods
LS7 lifters
Synergy Motorsports custom cam
WCCH Edelbrock heads
Vic Jr intake
Stock throttle body
Meziere electric water pump
ASP underdrive pulley
Turbo
83mm Borg Warner from Forced Inductions
ECM
BigStuff3 tuned by Earl Schexnayder @ Schexnayder Racing
Boost management
JGS wastegate
JGS blowoff
Boost Leash Co2 progressive controller
Fuel system
Magnafuel 4303 pump with MagnaFuel reg.
96lb injectors
Methanol Injection
Alky Control twin nozzle kit
M10&M15 nozzles
Transmission
FLT level 5 4l80e
Rossler Trans Brake
Pro Yank 3400 converter
Rear end
Stock 10bolt with TrueTrac
3.90 gears
Suspension
Front- DJM LCA's
Rear- Caltracs
Forged 370 9:1 CR
Stock crank
Wiseco Pistons
Callie's Rods
LS7 lifters
Vic Jr intake
Stock throttle body
Turbo
ECM
Boost management
JGS wastegate
JGS blowoff
Fuel system
96lb injectors
Methanol Injection
M10&M15 nozzles
Transmission
FLT level 5 4l80e
Rossler Trans Brake
Rear end
3.90 gears
Suspension
Front- DJM LCA's
Rear- Caltracs
