07 and Trick Trubo
Old Mar 18, 2007 | 10:21 AM
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by tahoe
How will you deal with the radiant heat from the turbine housing?
Even in normal driving in the hills, the turbine housing will be glowing red....
Br//
The only time that the turbine housing will be subjected to that much heat, is under boost. either alot of boost, or a some boost for great periods of time.
the trucks will climb a hills with little to no boost depending on the grade of the climb and how much load you may be carring.
I would recommend watching a boost gauge and if you see boost on the uphill climb for long periods of time, pull back on the throttle a bid.
Now the ac line that is closest to the housing has a heat cover supplied in the kit.
Old Mar 18, 2007 | 02:25 PM
tahoe's Avatar
The reason I am asking, is from what I have experienced in 25+ years with Saab turbos. (used to work as a test driver for 5 years at the factory)
If you drive a Saab on a flat highway at say 85-90 mph for more than 3-4 minutes the turbo is glowing dark red, only visible at night.
My next question was also answered above, the Trick set up is a bad idea for towing a travel trailer. (wich I do with my hoe)
Old Mar 18, 2007 | 11:30 PM
TrickTurbo's Avatar
Truck Sponsor
No you can tow with it, just do not race up hill while towing. I have towed a open car hauler with a car on it, but will admit never looked under the hood in the dark after doing so.
I have seen headers glowing thou, pretty interesting to see, does not hurt anything just interesting.
I think if you keep an eye on egt, boost, engine temp you could tow the same weight as the vehicle is designed to do, the tune has to be right.
lxcoupe
Sep 6, 2017 08:24 AM
nabozny21
Oct 17, 2015 07:47 PM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
TrickTurbo
Sep 23, 2015 08:41 PM
