Eastern VA, MD, DE, WV, PA, ME, VT, MA, CT, NH, NY, NJ, RI
Mods for 08'
Old Oct 11, 2007 | 12:04 PM
tdrumm's Avatar
While the truck sets for winter, I'd like to:
1.) Get my new trans installed
2.) Get my new cam installed (I've only had it for a year now)
3.) Get new Denny's HD driveshaft installed
3.) Get cowl hood and roll pan, and a few other misc. things in the front that I've had sitting around.
Maybe then I'll finally be able to drive my truck around March. It will only have been down for 10 months at that point.
Old Oct 11, 2007 | 03:01 PM
slownlow4.8's Avatar
mine are....
new tires
install 4.10
tune
work on my 33 sedan
Old Oct 11, 2007 | 08:06 PM
Breeze's Avatar
11 Second Truck Club
Since the trans broke this year I probably wont do much however I do want 60lb injectors but still no one makes a direct swap for our trucks so I will have to wait and see + this is my 1st winter being self employed and don't know what to expect Oh yeah and I want to add nitrous.
Old Oct 11, 2007 | 10:43 PM
Quik's Avatar
5 year bitches!
strip frame & repaint it
make turbo setup
rebuild 408
detail engine bay
paint rear
Long bars
possibly cage it
possible big brake upgrade
Old Oct 11, 2007 | 11:15 PM
TouchOfEvil04's Avatar
sighhhhh
04 ecsb:finish head instal lol
get 3.73's installed
install yank ss3200
fix vibration from improper shims
maybe.....longbars?????????? driveshaft loop
00RCSB : Hrmmm....YankSS3600
cam
heads
fast90/90 setup
e-pump
built tranny
longbars?????again???
prob gonna need some new meats/rims for the track
spray spray spray
i'm sure i'm missing alot of stuff but thats a big enough list for now.
Old Oct 11, 2007 | 11:37 PM
bluecajun5.3's Avatar
wider wheels and tires that hook!
Old Oct 12, 2007 | 05:30 PM
AeroKing's Avatar
lol i know where you can get a nice engine hoist...
Old Oct 12, 2007 | 07:25 PM
FLT Level V 4L65e, 3600 Vig are the 2 main things I would like to do. The fix all the little **** that has broken over the course of my college career that I didn't have time to fix. I also need a paint job and the front clip thing that Beastmode is doing. I have only been wanting to do that for 2 years now, but no point with out a garage. I need more money.
Old Oct 12, 2007 | 07:45 PM
AeroKing's Avatar
i guess i should post my list.
moving from the grille to back bumper...
- flex-a-lite tranny cooler
- complete A/C system reinstalled
- ABS delete & new brake lines
- block bored .030 over
- polished crank
- milodon oil pump
- ARP everything
- Eagle h-beam rods
- SpeedPro +21cc dished turbo pistons, forged alum, float pin
- Comp Cams 415 (500 lift, 210int, 215ext) hyd. roller
- Comp cams double roller set
- L35 4.3L heads
- Comp cams 1.6 billet full roller rockers
- LS1 valvesprings
- Comp cams hardened pushrods
- stock intake
- 65# injectors
- 3 bar map
- PT63E turbo
- homemade 3" stainless downpipe w/ ext. wastegate flange
- methanol injection
- ZQ8 steering box w/ new idler arm & pitman arm
- LS1 disc brake conversion, front & rear w/ drilled,slotted rotors
- Corvette ZR1 black wheels & tires, 275 in front 315 in rear
- PLX wideband
- 700R4 performance rebuild by Prime Gears
- 3k stall converter
- (mods for ECM for tuning) chip adapter, emulator, USB cable
- swap Autometer gauges (my Lunar set, gonna get a Pro-Comp set)
- rear end "freshened up"
- Caltracs bars (maybe, if i need them)
probably a ton of stuff i'm forgetting, but thats the major stuff.
Old Oct 12, 2007 | 09:39 PM
XLR8NSS's Avatar
Adkoonerstrator
Some sorta new truck and a power adder to go with it.
