Decissions
LS1Tech Sponsor
Turbo my Avalanche?
Thinking of doing the Trick kit,add an intercooler,meth and see how long 10-14lbs of boost lasts
Then of course the tranny will get built with a converter,clutches,shift kit ect.
Wonder if I can get this pig into the 12's with the 5.3l
LS1Tech Sponsor
10-14 is goin to kill that poor little 60E..
not too sure if that much boost is good to a DD 5.3....??
The high boost will be for fun.Wife will get 6-8lbs and towing will get 4-5. It will be tuned SD 2 bar of course to cope with different boost levels.
Originally Posted by Slowhawk
My Vette is still running 14lbs on the stock motor =3 years now
I guess its time for me to turn the boost up??
GFYS and STFU
FINALLY!!!
Turn it up to a max of 10 I would suggest, you won't recognize your truck.
Also I'm certain a 5.3 with 14 lbs of boost is gonna live alot shorter in a truck then it would in a vette. Just the whole weight thing. Heavier truck means bigger load which means more boost faster and more stress on the engine.
But if your gonna do that talk to some of the Florida Avalanche guys, they are rocking 14 psi on their DD's.
LS1Tech Sponsor
Originally Posted by Spoolin
FINALLY!!!
14lbs with alot of Meth is doable.It'a all in the tune.
