Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Truck going on dyno, should I fear for my driveshaft?
Old Aug 1, 2007 | 08:13 PM
  #21
trever1t's Avatar
2nd fastest 5.3 ECSB
I seriously doubt you have anything to worry about. I mean it happens but really, how often? I've been up 20 runs? You guys are making ME nervous, lol.
fine print: i in no way assume any liability for anybody's driveshaft, my own excepted
Old Aug 1, 2007 | 08:26 PM
  #22
1SlowHoe's Avatar
Destroyer of Transmissions
Originally Posted by Stoichiometric
The calc shows that shaft was good for 7900 rpm. I bet the balance has a lot more to due with failure than RPM.
That calc is for steel. Aluminum has a higher critical speed. But IMO you are correct, balance has more to do with it than strength.
Old Aug 1, 2007 | 08:54 PM
  #23
Stoichiometric's Avatar
Sorry Bill. The only thing I really care about is my transfer case. The purpose of my loops would mainly be to protect the front and rear shaft from taking out the case if one broke.
I need to research my rear axle a little bit (14bolt ff), the bolts that hold the front seal/cover on the pinion would make a perfect mounting area for a rear loop. I want to see if they also hold the rear pinion support before I pull some out to make a bracket.
I am worrying too much about all this stuff, lol. I just need to strap it down and pull until the valves float.
Old Aug 1, 2007 | 08:57 PM
  #24
trever1t's Avatar
Old Aug 1, 2007 | 10:49 PM
  #25
kbracing96's Avatar
I'm pretty sure that most all the failures have been with 1/2 ton trucks, you might be ok seeing how your a 3/4. FWIW my truck has been to 156 mph on the dyno once when I accidentally put it in 4th instead of 3rd
Old Aug 2, 2007 | 07:22 AM
  #26
agreif's Avatar
Totally. My DS was supposedly good to ~6100ish but took a dump at 5100/124MPH. Factory isn't going to balance a DS much past the speed limiter, just extra cost.
that's crazy, i didn't think there had been any steel failures.....that's even scarier.
Old Aug 8, 2007 | 05:01 PM
  #27
Last Call's Avatar
TOTM: January 2007
I have been in the low 150's at least 15 times on the dyno.. 3rd gear pull with the 4l80e, 31.5" tires, and 3.73 gear ratio.
I did take the factory driveshaft out and have it highspeed balanced though.
Old Aug 9, 2007 | 05:11 PM
  #28
I need to get mine balanced. I haven't been on the dyno yet, may not be for a while now.
Bumpers
Aug 4, 2024 09:44 PM
wrb002
Aug 31, 2015 12:00 PM
BennyB
Aug 1, 2015 08:48 AM
black6spdz
Jul 16, 2015 01:32 AM
FlowmasterMufflers
Jul 9, 2015 11:35 AM
