Relatively stock Nissan VK56VD dyno
I finally saw a dyno video of one and it put down 310 at the tire bone stock and something like 340 ft/lbs of torque.
I just changed up the exhaust on the M56. Removed the secondary cats, factory Y, resonators, and rear mufflers. Dual 2.5" from the manifold cats, to a X pipe where the factory pipes split after the Y into the resonators, then magnaflow magnapaks where the resonators once were and 2.5" pipes to the factory exhaust tips I cut off the factory mufflers and opened up enough to fit the 2.5" pipes. Sounds VERY mean now and power is up across the whole rpm range. I have not even touched the tune yet but I got on it on an on-ramp that I usually can hit 70 mph by a specific marker in the road and was doing nearly 80 mph when I hit that point. It is up a good 40+ hp from exhaust work alone. Will get another dyno someday soon to know where it stands but it pulls very noticeably harder, especially in the 2,500-6,500 rpm range. Even part throttle kickdown at 70 with the tach at 2,500 rpm it pulls noticeably more responsively. This 11.5:1 5.6 loves to breathe and the factory straw like exhaust was just not cutting it. I left room at the rear where the factory mufflers were to add vibrant resonators or a pair of 14" large case magnaflows to tame it down even more but at this point I love the sound even if it is a bit loud and aggressive. I kept hearing how much low-end torque it would lose, but it knocks the back tires off practically at will through first gear and I am running taller/wider than stock P275/40R20s on the back.
https://www.youtube.com/watch?v=vIRBIR19A1o
https://www.youtube.com/watch?v=XUAP5UjgWxg
Stalking and being a predator is illegal in 50 states. If I ever caught someone taking pictures of the underneath of my vehicle, castle doctrine is in full effect.
Those engines are traditional port fuel injection and do not suffer the same carbon buildup a direct injected engine like my M56 does. So you sir take that **** out of my thread!!!
