Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Please estimate some numbers?
Old Sep 28, 2009 | 09:54 PM
0235SS93's Avatar
Default Please estimate some numbers?
Well, since my dad is a rebuilder, we are always tinkering with something or building some project. He has an 05 Chevy SS Intimidator that's hit in the front. So obviously, it's a 2WD LQ9 6.0/4L60E. He wants to build a bad N/A street truck that he could DD if he had too. So, I sat down and compiled this list of motor/trans modifications. Could you guys and gals give me a estimate of hp/tq numbers as well as 1/4 mile times? Thanks in advance!
Circle D 278MM Street Series Torque Convertor
Texas Speed 228R Cam Package
243 Casting Heads
Sonnax Aluminum Accumulator Pistons
Transgo Separator Plate
Transgo HD-2 Shift Kit
Vette Servos
TruCool MAX Trans Cooler
Custom Wideband Tune
Coated OBX Long Tube Headers and Piping
Moroso Spiral Flow Mufflers
Volant CAI
160* Thermostat
8.1L Marine Injectors
Old Oct 1, 2009 | 06:35 PM
12 Second Club
I would guess around 480 fwhp (380) wheels. Maybe a 13.3 @ 100 mph.
Old Oct 1, 2009 | 06:42 PM
dirt track racer 81's Avatar
get some lower gears as well..4.10-4.30-4.56. id also get a bigger cam..have the heads milled as well
Old Oct 1, 2009 | 06:47 PM
charcoal03silvy's Avatar
Some ARH stainless headers!
Old Oct 1, 2009 | 07:32 PM
dlt76028's Avatar
i wouldnt do the obx headers, they have small primaries. i'd run pacestters. mill the heads for around 11.1 compression and you should see 400whp. btw i have that stall and its great dd, but wont 60' for nothing, 1.9s...
Old Oct 9, 2009 | 10:05 AM
03_SS_22's Avatar
+1 for milled heads, bigger cam, and bigger stall
Old Oct 9, 2009 | 10:52 AM
LS1FREEK's Avatar
13 Second Truck Club
+1! to big cams and stalls!
Old Oct 9, 2009 | 05:19 PM
BadAssChevy327's Avatar
man all it would take for me to make 400 wheel is a milled set of 243's and a cam?sweet deal.
i say hook your pops up. but before you spend big money on converter and building the 4l65E that your 05 has in it. id consider a 4l80 with that and the 14 bolt rear you should have plenty of long time fun..before the g-80 breaks
Old Oct 9, 2009 | 05:39 PM
GMCtrk's Avatar
I've had both. The primaries are the same size. And Pacesetters are garbage crap in comparison.
Old Oct 9, 2009 | 06:26 PM
dlt76028's Avatar
not true. obx are only 1 5/8 and pacesetters are 1 3/4
https://www.performancetrucks.net/fo...&highlight=obx
