Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Off the Dyno, opinions on these numbers
Old Jun 4, 2013 | 09:27 PM
TheBurlyMan's Avatar
Default Off the Dyno, opinions on these numbers
2011 6.2L CCSB 4x4 Z71 turning 20" wheels , 4.10 gears
TVS2300 @ 6psi, ARH LT headers with cats, Corsa 3.5" muffler, br6ef plugs
-made 460.5rwhp, 465.3rwtq
Anyone with similar power numbers have track results? Is this enough to get me into the 12's?
Old Jun 4, 2013 | 10:20 PM
swift700's Avatar
I think that that should get you into the 12's. Can you pulley it down a bit?
Old Jun 4, 2013 | 10:33 PM
I wanted to pulley down, but the tuner told me I have plenty of injector but I was out of fuel pump. Currently there does not seem to be many great/easy solutions for these pump setups.
Old Jun 4, 2013 | 10:58 PM
silverado6.2's Avatar
The power your making should do 12's if the rest of the truck is up to it. What converter do you have?
Old Jun 4, 2013 | 11:07 PM
GONEB4U's Avatar
10 Second Club
If you have a flex fuel truck then you have enough pump for around 600rwhp.
Old Jun 4, 2013 | 11:43 PM
I am still on the stock converter and yes the truck is flex fuel. I know the converter is going to kill my times but I drove my GTO for a year with a 3800 converter and it was miserable. Likely setup way to loose but still.
I am also still on the stock trans cooler and damn that trans heats up really fast now with the supercharger and such. I am waiting on the member here to complete the mounting brackets for the NNBS 40k cooler...
Likely safe to get another pulley then? even with the 10.5:1 compression?
Old Jun 5, 2013 | 12:08 AM
GONEB4U's Avatar
10 Second Club
Pulley down to 10-12psi and install a meth kit to kick in at 7psi.
Old Jun 5, 2013 | 01:37 AM
smokeshow's Avatar
Mod with training wheels
I was able to pull well over 500hp out of my non-flex fuel gmt900 before I saw pressure drops. Odd that you were already out of pump. What AFR?
Old Jun 6, 2013 | 07:39 AM
Smokymance's Avatar
Great numbers @6psi...man i need some LTs...
What size pulley you have?
Old Jun 6, 2013 | 07:44 AM
Choda's Avatar
those are great numbers, get it to a track
