Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
new numbers with 3.0 pulley
Old Nov 24, 2007 | 07:11 PM
sirk's Avatar
Default new numbers with 3.0 pulley
radix , 3.0 pulley, afi performance tune, air raid intake , magnaflow catback on a 2006 vortec max silverado. wont let me upload the chart ( to big ) but i put down 429 hp and 470 torque. this was on a dynojet at 70 degrees.
Old Nov 24, 2007 | 07:42 PM
usarmyman's Avatar
Verry nice numbers.
Old Nov 25, 2007 | 12:11 AM
oneslammedgmc's Avatar
What psi does the 3.0 pulley make? I don't own a supercharger and don't know either what they make on certain pulleys.
Old Nov 25, 2007 | 12:17 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Depends on intake/exhaust setup but a Maggy on a 5.3L/3" pulley should be around 9-10lbs. Slightly less for a 6L
Old Nov 25, 2007 | 12:19 AM
99Silverado5.3's Avatar
Is that a ho 6.0?
Old Nov 26, 2007 | 10:10 AM
sirk's Avatar
it is the h.o. 6.0 ( lq9 )
it makes 7.5 psi.
Old Dec 7, 2007 | 07:02 PM
terravast4's Avatar
does 8.5 sound low for a 2.8 pulley on a 5.3?
Old Dec 7, 2007 | 09:32 PM
sirk's Avatar
im not super familiar with them but yes it does seem a little low. do you have headers or a cam? that will lower it sometimes.
Old Dec 9, 2007 | 10:05 AM
terravast4's Avatar
yes, and 3" exhaust.
Old Dec 9, 2007 | 09:08 PM
sirk's Avatar
well with the headers you will lose some boost as boost is really a measure of pressure caused by restriction. hence less restriction=less boost. depending on your cam you may be losing some boost. whats the overlap?
