Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Made 943HP... But what's best way to load a dynojet?
Old Mar 27, 2015 | 02:42 PM
Atomic's Avatar
I have a gauge for that
Fwiw, I picked up 6mph or so in the 1/8th by going to a better converter.
Old Mar 27, 2015 | 03:32 PM
Choda's Avatar
Originally Posted by foose04
So has that worked best for you to keep the boost Stable? Say 3500 rpms, apply dyno brake get 10-15psi online and green up the dyno and let it sing?
I have never had the time or need to do this basing it off a certain PSI. it only takes a second or two and let it rip. Trying to get it to a certain PSI will mean holding the dyno brake longer and I dont wanna do that.
... With my Yank TT3000 = 465 hp 505 tq unlocked vs 489hp 566tq locked. ouch. 24hp 61tq at the tires.
Old Mar 27, 2015 | 04:00 PM
blownescalade62's Avatar
Find a real dyno! Those never give true numbers anyway! Load bearing Mustang Dyno for true numbers and loading.
Old Mar 27, 2015 | 06:55 PM
smokeshow's Avatar
Mod with training wheels
I'd trust a Dynojet's numbers long before I'd trust a Mustang, not because of the dyno, but because people generally don't know how to run their Mustang dynos... 9 times out of 10 I can spot a Mustang dyno just by seeing what the graph looks like.
Old Mar 27, 2015 | 08:00 PM
George C....'s Avatar
Formerly ScreamingL
this man is correct, Ive been on MDs for yrs and the owners typically cant set them up correctly
Old Mar 27, 2015 | 10:11 PM
Lol why cause a dynojet gives a higher number? Thats why most don't use a Mustang because of setup. But if setup gives true numbers.
Old Mar 27, 2015 | 10:49 PM
smokeshow's Avatar
Higher or lower numbers have nothing to do with it.
Old Mar 28, 2015 | 08:25 AM
Formerly ScreamingL
Many times the operator of the MD can swing the numbers ....MD have there place but they also are horrible if not setup right and display incorrect numbers and wrong rpms
On a DJ there is no setting up so numbers are more realistic
Old Mar 28, 2015 | 11:50 AM
Numbers are always over inflated on a dyno Jet! Been proven many times over! A in ground mustang load bearing dyno is a true dyno.
Old Mar 28, 2015 | 12:58 PM
Formerly ScreamingL
if they are over inflated then explain this....Same car same tune same day....435 rwhp on a MD and 436 on a DJ
dynos were 40 miles apart
