Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
heads numbers
Old Feb 5, 2009 | 10:29 PM
RickLowpez's Avatar
on a dyno jet.this was corrected,uncorrected was 414 rwhp and 389ftlb the weather was 59 deg outside
Old Feb 5, 2009 | 11:11 PM
GMCtrk's Avatar
those are truly incredible numbers with that small cam. wow.
Old Feb 5, 2009 | 11:27 PM
RickLowpez's Avatar
yup 220/220 581/581 112 and it pulls all the way up 2 6700 rpm
Old Feb 5, 2009 | 11:33 PM
dlt76028's Avatar
same cam tombstone has... maybe i should down grade from 224 to 220 then again my dyno only went to 5900rpm
Old Feb 5, 2009 | 11:34 PM
GMCtrk's Avatar
Guess it shows that it's all in the heads. Hopefully my PRC LS6's work as well as the stage 2.5 5.3s
Old Feb 5, 2009 | 11:36 PM
dlt76028's Avatar
thats what i beleive. i think you can easily pick up 40/40 with good flowing heads. didn't you say tsp would port heads you send to them for $6xx?
Old Feb 5, 2009 | 11:44 PM
GMCtrk's Avatar
Yup. $650 I believe, not sure if that includes return shipping or not.
Old Feb 6, 2009 | 12:36 AM
stock48's Avatar
9 Second Truck Club
That's really good power. You must have had negative DA for the dyno to be corrcting backwords.
Old Feb 6, 2009 | 12:39 AM
blackbeast ss's Avatar
damn nice numbers. id like to see the power curve of your run. which gear did you guys do the pull in? did you get any locked numbers?
Old Feb 6, 2009 | 01:16 AM
RickLowpez's Avatar
done in 3rd gear with the converter unlocked
