Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Guess my numbers
Old Feb 12, 2013 | 09:04 PM
BGERALD's Avatar
Originally Posted by dirt track racer 81
310-320
Seems a little low man
Old Feb 12, 2013 | 09:05 PM
BGERALD's Avatar
Originally Posted by brandon6.0
hey i live in ga. PM a lil info about where u will be doing the dyno at, if u dont mind.
I say 330/345
Pm sent!
Old Feb 12, 2013 | 10:04 PM
dirt track racer 81's Avatar
Low compression, small cam, stall converter, big tires and wheels in a second gear pull is what I'm taking into consideration. On a dyno jet that reads higher you might get it.
Old Feb 12, 2013 | 10:12 PM
BGERALD's Avatar
Valid point. I need 243s and a pat g spec
Old Feb 12, 2013 | 10:23 PM
It would help you out tremendously getting a bigger cam and higher compression, l92 heads would be a great option too! Have them milled .030 will put you at the same cc as the 243 heads. Then you will be close to the 385-400 hp range.
Old Feb 13, 2013 | 12:32 AM
WhiteX's Avatar
343hp
Old Feb 13, 2013 | 09:33 AM
BGERALD's Avatar
I want to get some 243 and have milled and p&p with a cam mid to upper 220s. That's ultimately my Goal
Old Feb 13, 2013 | 10:26 AM
TXSZ66AVLANCHE's Avatar
I think the 243 or 799 heads would be a better choice for your truck, the large intake port CC of the square port heads are not as good for down low torque which trucks with big tires really needs.
Old Feb 13, 2013 | 11:09 AM
I had no problem pulling a boat in overdrive up and down hills and never pulled the motor down. To each their own tho.
Old Feb 13, 2013 | 12:00 PM
Jake99's Avatar
Stock bolt on lq4 makes right around 300rwhp, id say 350 with that cam but down 20 with that wheel/tire combo so 330 sounds about right to me. Time wise will all depend on your weight, truck hight, and wheel/tire combo. We have gone 13.1 @ 101 in a 4400lb truck in 5000da with an all stock lq4 in it. Getting everything to work with your engine and proper tuning gos a long way.
