Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Finally got a dyno tune for my truck
Old Aug 26, 2014 | 11:10 PM
TheBeeblebrox's Avatar
Default Finally got a dyno tune for my truck
Did a 6.0/80e swap in my truck but had to rebuild the engine, finally got everything back together and broken in!
Specs on the engine: '02 LQ4 that I went .005 overbore with forged flat-top pistons w/Total Seal rings and forged i-beam rods w/ARP bolts, stock crank checked out ok, used King XP bearings and stock cam. Built by RPM.
Heads are stock 317's with a valve-job, LS6 springs, Comp trunnion upgrade, chromoly pushrods, GM hi-volume oil pump, LS2 timing chain/gears, and LS7 lifters.
Stock '99 5.3 intake/throttle body and stock exhaust manifolds/y-pipe into a flowmaster 70 series dumped at the axle.
Trans is a Jake's stage 2 80e with a stock re-man torque converter.
It made 317 hp and 362 ft-lb. We went on the safe side of the tune, I was surprised by the numbers, makes some good torque and is fun to drive
Might do a mild cam after my wallet recovers.
RPM did a great job on the tune, much better than the mail-order I had from Nelson, shifts nice on the street with very smooth power delivery.
This was the final pull
Got a vid of the 2nd or 3rd run can't remember
6.0 Dyno run - YouTube
Old Aug 27, 2014 | 03:45 PM
black00chev's Avatar
Slowest turbo build ever!
Do a nice little JFR(stock48) spec Isky cam and let that motor breathe! I bet you would pick up another 50hp easily.
Still awesome numbers for whats pretty much a stock motor.
Old Aug 27, 2014 | 07:58 PM
Thats what I was thinking, maybe in a year or so I'll get a custom spec cam for it.
But for now I'm enjoying that torque.
Old Oct 22, 2014 | 09:58 PM
10 Second Club
Gives me some hope, I have dished pistons - but changed the cam. Hoping it will put down similar power.
Old Mar 15, 2015 | 02:49 AM
Fast_six oh's Avatar
Bottom-end looks strong for sure
Old Mar 15, 2015 | 02:50 PM
Thanks! Just put a Circle D 258mm triple disk 3200-3400rpm stall in it to drop it right in the meat of the torque curve, and it pulls like a freight train, puts a smile on my face every time haha.
Old Mar 15, 2015 | 06:02 PM
Ricksilvy's Avatar
Nice #'s.
wrb002
Aug 31, 2015 12:00 PM
FlowmasterMufflers
Jul 9, 2015 12:23 PM
FlowmasterMufflers
Jul 9, 2015 12:00 PM
FlowmasterMufflers
Jul 9, 2015 11:35 AM
NuckenFuts
Jul 9, 2015 08:45 AM
