Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Fairly Stock 4.8L and S475 on 12psi
Old Apr 20, 2014 | 11:23 AM
timmay208's Avatar
Oakley, did you disable all your o2 sensor? Or how did you do the pass side with trick manifold being it has no bung
Old Apr 20, 2014 | 11:57 AM
oakley6575's Avatar
No I'm still running the front 02's. Rick puts the bank two oxygen sensor in the down pipe which I don't really like but it does seem to work. It doesn't have any problems keeping cruise and idle at stoich. If you look at the trims on the scanner, bank two always shows wacky high numbers (+10-13%) and bank one has to compensate. So it's not correct but the wideband does show lambda 1 in closed loop
^^ The S475/83 isn't too laggy on the street. I'm in full boost by 4400rpm if I remember correctly. I've never had a smaller turbo so I can't say for sure but I don't think I would like a turbo to spool any quicker than this one. I like being able to drive pretty much in N/A form while cruising and then unleash the beast when I want to.
thunder550
Oct 8, 2015 04:53 PM
Ketis
Jul 23, 2015 12:37 PM
Suburban2500
Jul 19, 2015 04:50 PM
Moto733
Jul 12, 2015 10:25 PM
NuckenFuts
Jul 9, 2015 08:45 AM
