Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
dyno results- T1 cam. give me ur opinions
Old Jun 4, 2007 | 11:57 PM
blksilverado's Avatar
Default dyno results- T1 cam. give me ur opinions
Well I finally got the truck dyno'd and tuned. The best numbers i got were 290hp 266tq. I think its got more in it tho. Correct me if i;m wrong, but shouldn't my torque be putting up higher numbers? I am really happy with the tune. It idles much better and throttle response alot better as well. Now only thing i think that might be holding me back a little is the stock airbox. My cold air setup that i had cracked, so i threw the stocker back on.
Mods are as follows.
T1 cam- 221/221 558/558 112+4
7.4 hardened pushrods
918 springs
Fuddle 3200 2.0 str
hd-2 shift kit
corvette servo
160 thermostat
Pacesetter LT
http://i151.photobucket.com/albums/s...dynosheet1.jpg
Old Jun 5, 2007 | 12:14 AM
Sport Side's Avatar
What gear was the pull made in? Looks like 2nd. A 3rd gear pull will show higher numbers. Next time, lock the converter so the pull can be made earlier in RPM. Also, with the converter locked, it will not flash causing that TQ spike you see at the beginning of the pull. Do you have headers?
Old Jun 5, 2007 | 12:48 AM
bluecajun5.3's Avatar
11 Second Truck Club
you need some headers.
Old Jun 5, 2007 | 01:29 AM
actually i got headers. forgot to put that in..
Old Jun 5, 2007 | 01:48 AM
RandomHero's Avatar
what size rims do you have? If you're running something like 22's then that might be where you lost some power. Although horsepower is usually what's affected by heavy wheels, not torque.
Old Jun 5, 2007 | 02:08 AM
I have 20" rt-s wheels. they are pretty damn close to stock size overall. i thought of that too, but don't think that would effect it.
Go5.3tt06
25
Sep 4, 2016 10:25 AM
01silvy
Sep 26, 2015 10:20 PM
jtphelps289
Sep 11, 2015 06:37 PM
Greatdivider
Sep 9, 2015 09:52 AM
echoman
Aug 22, 2015 01:53 PM
