Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Dyno Day results and Vid...LOUD!
Old May 27, 2008 | 10:03 PM
  #61
nonnieselman's Avatar
Originally Posted by Spoolin
Will stock 3.42's work fine? Do they have hardened one's? I don't wanna put 800 hp to some stock gears just so they blow up on me! The lower ratio I go the harder it's gonna be on the tranny and gears so I don't want to put a weak link anywhere in the drive train.
Originally Posted by trever1t
OEM gears are the best....believe it, they got that part right. Doit! 3.42's to build boost off the line and wow, sure duper gas milage on the freeway!!
From what ive read, Stock gears are stronger than Aftermarket.
And the higher ratio the stronger they are. (3.42s are stronger than 4.10s) Altho they do put a harder load on your trans, but you have a 80E for a reason right?
I like my 80E/3.42/29" tire combo.. 1650rpms @ 55 and 2100@70mph.
With my lil LQ4 and 60mm STS, I see no vacuum at 2250-2300 and full 5psi @2800rpms.. I couldnt imagine takin off at 4k..
Text me bout them gears.
Old May 27, 2008 | 10:17 PM
  #62
Spoolin's Avatar
GFYS and STFU
Stop being a homo and send me a paypal request already for how much you want + shipping.
Will PM you with email address...
Old May 27, 2008 | 10:30 PM
  #63
Spoolin's Avatar
GFYS and STFU
Originally Posted by Rick@Synergy
All you will do is shift your power band up about 500 RPMS, spool later and make power higher. Good for dyno graph, not for track.
Try the gear change first.
R
Your not saying it's gonna stay the same just move further up are you?
I'm ok with shifting the power band up as long as it also extends it too. I kinda like the way it drives and the way the boost comes in. As long as the bigger A/R does in fact widen the power curve.
Old May 27, 2008 | 11:22 PM
  #64
AdioSS's Avatar
12 Second Club
I'm also going to stick either my old 3.23 or some 3.42 gears in the rear end because these 4.10's are causing me to go through the gears way too fast. I hope the smaller gears will load up my engine much better and I can see full boost in 1st and 2nd gear rather than only in 3rd gear.
Try the 3.23s if you've already got them.
60mph is just 1500 RPM and 80mph=2000RPM in my 60E/3.23/30.5" truck. I'm consistantly getting well over 20mpg highway (usually closer to 22) in my stock 5.3L truck.
I could see very low 12s at around 120mph from your truck if you could get it to hook up at all.
When on the street, what RPM do you shift?
Old May 27, 2008 | 11:24 PM
  #65
2005 Silverado's Avatar
SPAM HUNTER
IDK about after my swap (cant figure out the cruise control with the DBW setup) But with 3.23 my 4.3 was getting 22+ everywhere.
Dustin
Old May 27, 2008 | 11:31 PM
  #66
Spoolin's Avatar
GFYS and STFU
Well my mpg's will go up but that's not really an issue really, I mean it's a bonus but it's not why I'm doing this. With my old 3.23's and 60e and 5.3 I was seeing 20's mpg as well but I know I won't be seeing that now.
  #67
Spoolin's Avatar
GFYS and STFU
WOT or cruise?
Old May 27, 2008 | 11:37 PM
  #68
AdioSS's Avatar
12 Second Club
WOT shifts, like in high gear
Old Jun 10, 2008 | 02:59 AM
  #69
Spoolin's Avatar
GFYS and STFU
WOT w/ the 4.10's and 80E is
1-2 shift @ 55mph
2-3 shift @ 85mph
top of 3rd gear is 136mph
Old Jun 10, 2008 | 08:24 PM
  #70
00Silverado's Avatar
Nice numbers Julien. Any L.A. area meets coming up any time soon?
