Dyno Day results and Vid...LOUD!
#61
From what ive read, Stock gears are stronger than Aftermarket.
And the higher ratio the stronger they are. (3.42s are stronger than 4.10s) Altho they do put a harder load on your trans, but you have a 80E for a reason right?
I like my 80E/3.42/29" tire combo.. 1650rpms @ 55 and 2100@70mph.
With my lil LQ4 and 60mm STS, I see no vacuum at 2250-2300 and full 5psi @2800rpms.. I couldnt imagine takin off at 4k..
Text me bout them gears.
#62
GFYS and STFU
Will PM you with email address...
#63
GFYS and STFU
I'm ok with shifting the power band up as long as it also extends it too. I kinda like the way it drives and the way the boost comes in. As long as the bigger A/R does in fact widen the power curve.
#64
I'm also going to stick either my old 3.23 or some 3.42 gears in the rear end because these 4.10's are causing me to go through the gears way too fast. I hope the smaller gears will load up my engine much better and I can see full boost in 1st and 2nd gear rather than only in 3rd gear.
60mph is just 1500 RPM and 80mph=2000RPM in my 60E/3.23/30.5" truck. I'm consistantly getting well over 20mpg highway (usually closer to 22) in my stock 5.3L truck.
I could see very low 12s at around 120mph from your truck if you could get it to hook up at all.
When on the street, what RPM do you shift?
#66
GFYS and STFU
Well my mpg's will go up but that's not really an issue really, I mean it's a bonus but it's not why I'm doing this. With my old 3.23's and 60e and 5.3 I was seeing 20's mpg as well but I know I won't be seeing that now.
#67
GFYS and STFU
Try the 3.23s if you've already got them.
