Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
93 VS pump E85 results...
Old Jan 20, 2026 | 02:44 PM
10 Second Club
Default 93 VS pump E85 results...
A few weeks ago, I took my truck to the dyno I normally test on. Did 3 pulls on 93, added some pump E. Only saw 40% on HPT, still managed to consistently pick up 7rwhp & 7rwtq. Have not had a chance to get track results. I need to get my logs to the tuner that helped me with the flex fuel tune. Timing seems high, but no knock detected. Plugs show zero signs of detonation.
Old Jan 20, 2026 | 06:39 PM
smokinlmm's Avatar
It’s a waste of time unless you can get the % up to at least 70%. I added some true E85 from a 55 gallon drum to mine and picked up 60 rwhp. That was on a 75% E mix with 105 octane. At a 65% mix it was only 25 rwhp and that was mostly from the cooling effect that allowed for more timing. With boost it helps a lot, NA not so much.
Old Jan 21, 2026 | 06:28 AM
10 Second Club
I am mainly doing it for track days, hoping there's about a .1 advantage over regular 93. This engine is about 10.5:1, my new engine will be over 11:1 compression.
Old Jan 21, 2026 | 11:36 AM
smokinlmm's Avatar
If you can get the mix over 72% you should pick up 20 plus rwhp. I swear less than 60% puts you down or on equal power as good 93. Try adding some race gas 100+ octane to your 93 and make a witches brew. NA you don’t need the cooling, your after the octane boost.
Old Jan 21, 2026 | 02:22 PM
10 Second Club
Even with a naturally aspirated engine? I had several people tell me that I likely gained the majority of the power on 40%, and would see maybe 1-2 more at 60-70%.
Old Jan 22, 2026 | 05:06 AM
smokinlmm's Avatar
They are wrong, most power from E85 comes from a mix greater than 70%. You will get a cooling effect that helps make power but to get the real gains you need the extra octane from E85.
Old Jan 22, 2026 | 12:21 PM
RDF1's Avatar
DuNnO
5 Year Member
I agree.
It seems 70-75% is the sweet spot. Higher the better but 10-60% just doesnt seem to help much at all.
62nalide
11
Oct 12, 2016 11:23 PM
bigsapper
Nov 9, 2015 07:14 AM
Ferocity02
Nov 15, 2014 01:22 PM
Rick_Vor
Jan 27, 2009 02:35 PM
dropkick13
May 18, 2007 10:34 PM
