93 VS pump E85 results...
A few weeks ago, I took my truck to the dyno I normally test on. Did 3 pulls on 93, added some pump E. Only saw 40% on HPT, still managed to consistently pick up 7rwhp & 7rwtq. Have not had a chance to get track results. I need to get my logs to the tuner that helped me with the flex fuel tune. Timing seems high, but no knock detected. Plugs show zero signs of detonation.
It’s a waste of time unless you can get the % up to at least 70%. I added some true E85 from a 55 gallon drum to mine and picked up 60 rwhp. That was on a 75% E mix with 105 octane. At a 65% mix it was only 25 rwhp and that was mostly from the cooling effect that allowed for more timing. With boost it helps a lot, NA not so much.
If you can get the mix over 72% you should pick up 20 plus rwhp. I swear less than 60% puts you down or on equal power as good 93. Try adding some race gas 100+ octane to your 93 and make a witches brew. NA you don’t need the cooling, your after the octane boost.
It seems 70-75% is the sweet spot. Higher the better but 10-60% just doesnt seem to help much at all.
dropkick13
May 18, 2007 10:34 PM
